RCU Forums
-   RC Giant Scale Cars (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/)
-   -   Vertigo Performance Clipless front axle extenders for the HPI Baja now available (https://www.rcuniverse.com/forum/rc-giant-scale-cars-234/9939925-vertigo-performance-clipless-front-axle-extenders-hpi-baja-now-available.html)
vertigo performance 08-17-2010 11:42 AM
Vertigo Performance have released our clipless/boltless front axle extenders. We have had this product in use for nearly 2 years and finally have them available to the public.
Some things that set Vertigo Extenders apart from others on the market:
Design? - We are the only company to produce an extender that has options of narrow or wide stance so you can tune your front end for the track within seconds.
Clips? - PFT!!!! No clips here!!
Bolts? - What bolts? who uses bolts? not Vertigo, not when they can break and get stuck in your hubs.
Price? - Better than the competitor
Originality? As with the majority of our product line our axles extenders are just another product we have put into the market place before the competitor.
If you want to go clipless and don't want to go wider our axles work with stock rear hubs to retain the stock width on the front of your HPI Baja
When you are Bashing you may want a wider stance, racing you may not have the turn in you need with the wider stance so you can, within just a few seconds take your front end from wide to narrow by using any stock style rear hub on Vertigo Boltless/Clipless shafts.
Kit includes:
2 - Hollowed steel flanged shafts
2 - 8mm Extended hubs (the same hubs we have sold thousands of for the rear of the HPI Baja)
2 - 4x24 Hardened Chromed European made steel pins
2 - Rubber retaining rings
Check out www.vertigoperformance.com
http://www.vertigoperformance.com/images/VPPP1629ST.jpg
frumpy 08-17-2010 05:55 PM
RE: Vertigo Performance Clipless front axle extenders for the HPI Baja now available
Very nice,of course I don't have a baja anymore[:o]
sheograth 08-17-2010 06:32 PM
Great looking.
aluminum crusher 08-17-2010 07:42 PM
Yeah Vertigo way to go I need 2 sets of those for the front for my 5b and 5t, and I wish you had of made the narrow width hubs of your own. Because alot of us likes the closed hubs instead of the open hubs like the stock one's. I also need another clutch bell and pinion set up for my 5t along with your cf brake pads.
vertigo performance 08-17-2010 08:03 PM
Do you mean like this?
http://img.photobucket.com/albums/v3...bdelete002.jpg
The front shafts have a closed end so that there is no place for dirt to get in when using a stock rear hub on the front.
We realize everyone adding extenders will have rear hubs in their spare parts box, this being the reason we don't sell them with rear hubs. Also an enclosed rear hub would not seat all the way onto the front shaft as the end of the hub sits flush with the end of the shaft.
Thanks Crusher for the added support..
Cheers,
aluminum crusher 08-17-2010 08:07 PM
OK cool but I also just like the look of your material and would like to have matching hubs for front and rear.
vertigo performance 08-17-2010 08:15 PM
Shoot me an email, I would like to better understand what set up you run and if we have something that can accommodate your set up
[email protected]
Cheers,
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
