aelerons for gliders
MO
has anyone seen the lat control hinges in the easy flyer glider, servo is inside the wing at the fuselage and the control hinge in wing is flat it looks like a lever hinge with arm inside the wing
bob
bob
Spoilers and ailerons are two different things. Although outboard mounted spoilers have been used on some aircraft for roll control. But it's extremely rare to see them used that way on model airplanes. In particular on gliders since spoilers induce a lot of drag even for small deflection angles while ailerons induce camber and angle of attack changes that cost less for drag.
Goldenknight, A picture of what you're talking about would help us out.
Some years back there was a hinge and control link available that would activate a control surface without any external control horns. It involved a 45 degree dogleg torque rod sitting in a flat box cavity that fit into the control surface. If this is what you meant I have not seen them advertised for some years now.
The aileron servos in my Easy Glider are conventional.. laying flat in the wing out at the aileron location, with a pushrod to a horn on the bottom of the aileron.
I've used this type of direct drive for rudders, and ailerons.
The bent end has to be in a pocket in the aileron that won't be eroded by the motion.
ORIGINAL: goldenknight1
bob
bob
I have seen this type of hinge on several RTF gliders out of Hobbyking. Seem to be quite irregular as to whether they work well or not. I had two with those kinds of hinges and they did not work well at all. But that may have been how they were installed.
The style of hinge and activator all in one of this sort must have excellent close but not draggy tight tolerances. Any slop or misalignment at all and the whole thing turns into garbage in a hurry.
