RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Radian Orientation
Old 07-14-2011, 08:34 AM
Steve Steinbring
Default Radian Orientation
Here is how I painted my Radian to help with orientation and visibility. It works well really improves keeping track of the bird.
ID:	1635159   Click image for larger version
Old 07-14-2011, 08:46 PM
OzMo
OzMo's Avatar
Default RE: Radian Orientation
Good idea and well done. What did you use?
Old 07-15-2011, 12:53 AM
Steve Steinbring
Wish I could take credit for the idea, but that rightly goes to a gent in the Deland, FL club.
I used Krylon spray paint masked off with blue painters tape. The models foam is stable enough to accept the paint well.
Old 07-15-2011, 02:30 PM
GlenIronPa
Specificly Krylon H2O paint, its water based and cleans up with soap and water and foam safe. I found it at Ace Hardware on the internet myself.
Old 07-18-2011, 05:39 PM
aeajr
aeajr's Avatar
Other things you can use is the colored packing tape the use for slope gliders.
http://www.mountainmodels.com/produc...roducts_id=587
I have the dark blue tape from root to tip on the bottom of the wing.  As I fly toward myself from way out I can tell the orientation of the plane by which color I see. White means I am heading down.  Blue means I am heading up.  works great!     It may also add a little extra lateral support to the wing.
You can also use monokote trim sheets:
http://www3.towerhobbies.com/cgi-bin...ote+trim+sheet
Old 10-09-2011, 12:33 AM
ShipBear
Really looks good, going to have to do mine that way..
Later, Larry
