Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Dynaflite Drifter II question.
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 11-09-2011, 10:18 AM
electrogizmo
Default Dynaflite Drifter II question.
I'm restoring a Drifter II that has not flown for somewhere around 25 years. The plans and construction notes are long-gone. Can anyone out there tell me how far the CG reference is behind the leading edge of the wing.
Thanks.
Old 11-09-2011, 01:12 PM
Buran
Default RE: Dynaflite Drifter II question.
I just looked; the CG is located at the middle of the wing spar.
Old 11-09-2011, 01:33 PM
electrogizmo
That's simple enough. Thanks for your help.
Old 11-09-2011, 02:09 PM
BarracudaHockey
BarracudaHockey's Avatar
That brings back some memories. My first plane was a Craft Air Drifter II.
Good luck with it! Yep, CG on the spar.
Old 11-10-2011, 07:27 AM
Bax
If you need plans, contact:
[email protected]
Likely a set is in the archives and can be copied and sent to you. They can let you know what the cost would be.
Old 11-10-2011, 08:18 AM
electrogizmo
Yes......that's where I started. Great Planes told me the Drifter was a discontinued product when they acquired the Dynaflite product line. They have no records of it.
But thanks for your suggestion.
Old 11-10-2011, 04:38 PM
HIr/cer
My Feedback: (74)
Interesting! I was out of the hobby when Dynaflite was formed, combining Mark's Models, Craft-Air and Hi-Flight kits, and when Dynaflite was sold To Great Plains, I also assumed that the Drifter II was kitted by Great Plains under the Dynaflite line. The later Drifter II kits have the large Dynaflite name stamped on the box but apparently they were produced before the Great Plains aquisition.
BTW, the Dynaflite Piece O' Cake powered glider uses the same wing as the Drifter II and Great Plains did produce that kit. Altho the kit has been discontinued, the manual is still available on-line, with drawings of the the die cut sheets identifying the wing ribs.
A friend had a Drifter II as his first glider and it was a floater, better than my Wanderer. I have an incomplete Drifter II kit which I have been promising myself to build for some time. The Piece O' Cake ribs may still be available from Dynaflite; I bought a set a couple of years ago but they are best used for rib patterns.[]
Old 11-11-2011, 04:39 PM
juggler-3310
Electrogizmo, I have the plans for the Drifter II. If you want to get a copy and can't find them elsewhere, send me a PM.
juggler
