RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Wind speed limits?
Old 05-30-2012, 11:58 AM
Default Wind speed limits?
I want to build another leading edge gliders P-40 but a 48 inch this time and I don't know why I never asked before but what is about the max wind speed a sail plane like this can take? I plan to fly it off this mountain when I build it the black arrow is where I will launch it and fly from Ive been up there before
Old 05-30-2012, 12:14 PM
Default RE: Wind speed limits?
In general, a slope gliders wind limitation is the pilots skill and the vertical component of lift at your site. I've flown a 36" slope glider weighing 10 ounces in 55 mph winds and enjoyed myself. I've also flown a 5 lb glider and had no fun at all. If the slope in high wind doesn't generate much of a vertical vector then you will need a lot of weight to keep the glider from blowing back. Adding lead can help.
Old 07-17-2012, 03:36 AM
aeajr's Avatar
Generally you keep adding weight to increase wing loading up to the point where the wings break.  [X(]
How much wind did you have in mind?   100 mph?   10 mph?
My typical slope soaring days are between 7 and 20 mph.   Any of my planes can take that with enough ballast.
Old 07-17-2012, 03:14 PM
evan-RCU's Avatar
Wait, there's a good site in Austin??? I never found one.
Old 07-18-2012, 09:31 AM
Lnewqban's Avatar
Just a reference:
http://www.youtube.com/watch?v=Oix6s...eature=related
Old 09-02-2012, 06:22 AM
*Unbelievable* video!!! How much does one of those carbon fiber gliders cost? Brand? Site to purchase?
Old 09-02-2012, 08:26 AM
You can get the record holding planes HERE and HERE. They range from $350 (40") to $3800 for the 100" Kinetic (last I heard). You can get several 80" DS planes in the $1400 range. The larger birds usually require $500 in servos...often more.
Old 09-02-2012, 10:58 AM
Thanks!  Looking forward to your comment on my other post (about gliding flying wings in high winds).
Old 09-02-2012, 01:02 PM
I've got a 2m I built back in the 80s. It's your run of the mill builtup rudder/elevator, a pure thermal glider with polyhedral wing. I built it with a plywood ballast that could be put in while rubber banding on the wing. The box would hold just over a pound of lead.
I cast my own bullets so cast a couple of fitted weights. One was 8 oz, the other 16. Moderate days would get the half-pound weight, heavy days the heavy weight. I don't ever remember us not going sloping because the wind was too much, unless it was also below zero. ahhh those Minnesnowta days.
Old 09-28-2012, 07:33 PM
aeajr's Avatar
ORIGINAL: da Rock
Most of my slope soaring is done in the winter on Long Island, NY. Most of the time it is below 40, but sometimes it is in the teens. I have built up a pile of cold weather tools to make the cold weather flying fun, but it is still cold.
Old 11-08-2012, 02:35 PM
<span id="result_box" lang="en"><span class="hps">Here's a video</span> <span class="hps">in high winds conditions</span> <span class="hps">(about</span> <span class="hps">45mph)</span><span>.</span> <span class="hps">This</span> <span class="hps">is called</span> <span class="hps">foehn</span> <span class="hps">wind</span><span>.</span> <span class="hps">He blows</span> <span class="hps">relatively constant</span> <span class="hps">and</span> <span class="hps">usually</span> <span class="hps">several days</span><span>.</span> <span class="hps">The launch site</span> <span class="hps">is located</span> <span class="hps">in the Swiss Alps</span><span>.</span>
<span class="hps">The model is a</span> <span class="hps">Redback</span> <span class="hps">EPP</span> <span class="hps atn">60 "</span><span>span</span> <span class="hps">of EPP.
http://www.youtube.com/watch?v=FDgr7pbgh2g
</span>
<span class="hps"></span></span><span id="result_box" lang="en"><span class="hps"><span id="result_box" class="short_text" lang="en"><span class="hps">enjoy
</span></span></span><span class="hps">Alain</span></span>
Old 11-08-2012, 03:08 PM
The Redback in the Alps is fantastic!!!!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
