Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
R2 Hobbies Bluewing 1.4m EP "V" Tail Glider
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 07-10-2013, 04:01 PM
nauthst
Default R2 Hobbies Bluewing 1.4m EP "V" Tail Glider
I just received one of these in the mail, and found that though the components appear to be quality, it comes with no build instructions. I have never set one of these up before and need some help with the tail fletching, a "V" tail, and a blow up labeled drawing, especially since I will need to obtain replacement parts. The initial throws for that tail will be very important. Does anyone know of a build log for a similar sailplane model? I have e mailed the mfr. after checking his website, but I'd like to read other's experiences and advice.
Old 07-10-2013, 07:35 PM
TIA
TIA's Avatar
Default RE: R2 Hobbies Bluewing 1.4m EP
Pics will help...
Old 07-12-2013, 07:17 PM
nauthst
I'll need to get the digital camera out tomorrow morning and take shots of the parts I received in a ziploc bag with the kit. With one of the forum member's help, I was able to download and print the instructions for the Blue Wing, though looking at the previously mentioned parts, both extensions that slide into the tail-tube, I can see that the build instructions I now have are for the Mk1 version, which is a down-rev of the version I have. The add for this kit mentions it incorporates larger tail surfaces, which I have and they would probably break off in flight if I tried to glue them to the small surfaces on the inside of the "V" slot in it. The other extension has an inverted external "V" shape with a small hole toward the tail end for an included nylon screw. There are also two sections of "V" section fiberglas, one with a grommet bonded into it the same distance from the end. I will take pics of all this tomorrow. It appears the R2 "Speedo Mklll" has a similar tail build, but I can't bring the manual for it up- for some reason I'm getting an "Access Denied" flag from the website when I insert the Speedo's rcpl number.
Old 07-13-2013, 02:20 PM
nauthst
The first question here is whether to use the tail extension shown mounted on the sailplane, which I beieve is the Mk1 version for the smaller tail surfaces, or the configuration shown on the upper left which is heavier but will provide more support? This appears to be a common way to mount a "V" tail. Can anyone provide a link to a build log that includes a step-by-step guide to construction? The instructions I have show the control horns mounted underneath the elevators. I got a rear photo of asimular tail that shows the horns mounted on top of the elevators, which seems to be a safer place for them if practical.
