RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Greensleeves 2M Glider
Old 02-21-2014, 06:18 PM
Parkflyer939215
Default Greensleeves 2M Glider
Personal Notes for anyone buying a "Green Sleeves " 4 Channel Glider
 Two ( 2 ) Standard Servo's ( Elevator & Rudder )
This plane does not need Standard Servo's
Takes up to much space in servo tray
Adds additional unwanted weight
Used two Hitec H-82 Servo's - Saved 2 ounces
 Servo tray had to be replaced for smaller lighter servo's
 Servo Push Rods had to be reconfigured for free movement
 Hinged control surfaces installed by Green Sleeves
Alieron and Rudder surfaces had to be reglued with CA glue - Loose
 Wing hold down bolts
Hold down blocks in fuselage were tapped at an angle - not straight
 Battery compartment ( Nicad Batterys ) old technology
Recommend Li-po 3 Cell - 1800ma or better
Placement up front behind motor
 Velcro stap inside fuselage .. removed ( not needed )
added new Velcro on fuselage floor for Li-Po Battery behind motor
 8 x 4 Folding prop provided with kit .. way too small
Replaced with 11 x 6 folding prop assembly .. plenty of power
 CG point of 2 5/8 inch .. just a starting point
Actual CG point was found to be aft of this point .. more like 2 7/8
 Canopy needs some type of magnet hold down. The canopy screws on each
side are small and easily lost.
After making all the changes above, the glider flew great . very nice !!!!
I would not recommend this product based on workmanship and retail cost.
Old 02-21-2014, 07:56 PM
longsoar
longsoar's Avatar
do you have pictures or videos?
Old 02-24-2014, 06:02 PM
Parkflyer939215
Longsoar,
Best detail pictures of a Greensleeve 2 M gilder can be viewed here : http://www.marionvillemodels.com/rc-...r_5500271.html
http://www.greenmodelusa.com/Green-Sleeves.html
Nice video : http://www.youtube.com/watch?v=jxl58wOuUCY
Old 02-25-2014, 09:15 AM
aeajr
aeajr's Avatar
Thanks for the update. This one has been around for a while. Great recommendations.
