Valenta ASW20 - 4m
New to sailplane, I decided to build a Valenta ASW-20 4m. The build is actually going pretty smooth but I have a couple questions:
The first pertains to the winglets attachments to the main wings. Although they fit nicely using a carbon rod, how do you get them attached to the main wings so that they do not separate in flight? I was thinking small strong magnets.
I am used to RC planes and usually the wings are kept to the fuselage using either nylon screws or something similar. There are no such things on the ASW20, what do you guys use to keep the wings from separating from the fuse?
Cheers
Gaz
Cheers
Gaz
