Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Radian Pro with Futaba radio- motor programming
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 11-17-2021, 06:03 AM
ho2zoo
Question Radian Pro with Futaba radio- motor programming
Hello, I am an old glow/gas guy- been flying since 1991. Got a good deal on my first electric plane; a Parkzone Radian Pro. I use a Futaba 14 SG radio. Plugged everything in to the receiver and it all works except the motor. Beeps, chirps, and twitches slightly but will not respond the the throttle stick. ESC is plugged in to the throttle channel (3).
I guess it must be the endpoint adjustments. Tried various settings but the ESC will not arm the motor.
Surely someone has used a Futaba radio with a Parkzone plane. What are the radio settings to get the throttle to work?
Thomas
Johnaa (12-06-2021)
Old 11-17-2021, 06:26 AM
Bultaco360!
Reverse which ever channel you have the throttle plugged into, futaba pulse is backwards compared to JR/ Spektrum—-also throttle, aileron, elevator, rudder is the order for Spektrum receiver—- futaba order is a,e,t,r
Old 11-18-2021, 07:26 AM
ho2zoo
Had some help in one of the other forums, and I got it! Set the throttle to reverse and the limit to 135, travel to 100, which are the default numbers. Full throttle then powered the plane (with the prop off). Beeped and chirped at me, then pulled the throttle back to idle. However it did not beep any more. But the throttle works now! Now I just need some warm weather to try it out!
Thanks everyone!
Thomas
Johnaa (12-06-2021)
