Great Planes Spectra ARF
RE: Great Planes Spectra ARF
The Spectra is an electric version of the Spirit.
The Vista is a pure sailplane, more like the Spirit. The Vista EP would be similar ot the Spectra.
The designs are very close. It is possible that Tower bought the rights to the design from Great Planes, or that it is in fact the same plane under a different lable. The tower radios are all Futaba.
Common practice.
As for being a good first glider, yes, I think the Vistas or the Spirit or the Spectra are all good choices for first gliders.
Common practice.
Thanks Ed. Your advice is appreciated.
And another thing if you don't mind helping out again. The stock motor/ESC recommendation is 7 cells (8.4 V). If I went to 8 cells, would the ESC still be OK (I'd be running a higher current) or would I need to go to a C35 mentioned earlier. The clear plastic srapped ESC provided with the ARF looks awfully similar to the Electrifly C-25 (itmay just be the same picture of course), and 8 cells at 3000mAH wouldn't get to 25 amps, or is my logic illogical?
Currently I look like going down your recommended path, stock motor and ESC, gearbox 2.5:1 and then 8 cells of NiMH, but I don't want to cook the ESC first time out.
SRA
SRA
The ESC should be marked on how many cells it can take but I would be shocked if it could not take 8 cells.
8 3000 mah Sub C cells will give you many climbs but will weight about 18+ ounces.
Or you can go to an 8 cell GP2000AFHR or similar A size cells that can handle 25 amps+
This one is 2000 mah.
http://www.cheapbatterypacks.com/mai...ells&chem=NIMH
Not as much capacity, I would expect 5-7 good climbs, but the pack will be about 9 ounces or about 1/2 the weight of the SubC pack, and that is a HUGE difference in a sailplane. Short of going to Lipos, I would do this. Get two of these and you should have plenty of flying time. 5 climbs with some lift on each, let's say a minimum of 3 minutes would be 15 minuts of air time.
If you catch lift, you could be up for hours on one pack.
I've been talking with guys who fly sailplanes, and they say that the Spectra is a good thermaller but not so good at slope soaring. Does anybody have views on this?
I guess, like powered aircraft, one type won't do everything equally well, so maybe what they say has some merit, but for my first sailplane, I am looking for something that I can use for a range of flying. So will the Spectra do it all?
Thanks again.
Thanks again.
I have a Spectra I built from the kit back in the early nineties. I flew it for years with the stock 550 can motor, 8 X 4.5 Graupner folder and 1500mAh Nicd sub c's. It flew well with a moderate climb and I often got 45 min. soaring flights. I recently got it out of storage after a 15 year RC break. I am going to upgrade the can motor to a Himax 3510 1100 brushless that is a direct bolt on replacement for 550/600 can motors and put an 11" or 12" folder on it. Also ugrading receiver to a Berg 4, T-bird 36 ESC and 4000mAh Lipo. May also add spoilers if I can find some info on how to do it. I still see the Tower still carries the kit after all of these years. Must say something about the design.
Rick
Rick
#31
Thanks Rickochet. It does say something for the design.
I decided on a brushless motor and LiPo, and though I've received the box, motor, etc., I've yet to start construction.
#32
I have what used to ba a 2 meter Spirit with the stock Spectra motor driving a 3.5:1 gearbox turning a 15*12 folding prop on 3 cell lipos.
Climbs like a homesick angel with a 2.5 meter full house wing. On a 10 second run I can get 500 feet, Close the throttle and everything is trimmed so all I have to do is make the turns.
Stock is good but you can do so much better.
#33
I keep reading on the Spectra threads about the problems with the weak tail section. On the ARF both tail fins bolt on??? These bolt on's never seem to be as strong as when they are epoxied together???
The new Tower EP Vista seems to be very similar to the Spectra but the tail is epoxied together So it should be stronger????
Would they be very similar in flight characteristics?????
I am considering one of these two Sailplanes and from what I read the Tower Vista may be stronger????
However the Multiplrx Easy Glider EP RR may be the answer????
#34
I noticed back on page 1 that somebody is using 8 cells (9.6 V) instead of the recommended 8.4 V with this motor.
Just how much voltage will this motor take? For example could I power it with 3S LiPo, nominally 11.1 V, but peaking at 12.6 V. I thought not, but can somebody more knowledgeable than me on electrics (most posting on this thread, I'd say) clarify this for me. I thought that brushed motors had a fixed voltage and if you put more into them they'd burn out, and only brushless used a range of voltages.
I had intended going outrunner, but am having weight problems, i.e., too light. The supplied brushed motor is quite heavy, and right out front. An outrunner is about a quarter of the weight, and the LiPo battery pack is also very light, so I'm going to have CofG problems if I don't add lead, something I'm loathe to do.
I'm thinking I may go back to the supplied motor, etc., but need to know if I can use the 3S LiPo battery. If it lacks performance, I can then add a gear box.
Last thing; is a battery pack made up of 8 X 2400 maH AA (NiMh) cells likely to be able to supply the current required? In theory they should, but I'm not sure.
Thanks for the advice; it's always appreciated.
#35
ORIGINAL: Semi Retired Aviator
Brushed motor is likely to be around 50% efficient while the brushelss should be around 80% or better. So more power gets to the prop and less gets lost as heat.
A cells or even 4/5 A cells may be able to deliver the power you need. Depends on the MFGs rating. If the supplier says their battery can deliver 30 amps, then I would look to use it at no more than 25 amps so as to not over stress the pack.
#36
ORIGINAL: TomTreese
If you want, you can epoxy on the tail of the. Nothing stopping you. Bolt on is for ease of assembly and transport. But if you want to glue yous on, you can.
#37
Thank for your advise on another thread. I bought the Multiplex Easy Glider EP RR. A great choice.
I have 18 flights with a 21 minuted duration flight.
I am using a 9.6V 8 cell NiMH battery which give me 6-7 minutes of power to climb to 500 feet and still enough to line up with the runway.
I am very glad I bought the foamy A/C since I failed to keep the nose down on the second landing and it stalled and went in nose first, a bit hard. It took 5 minutes for a CA fix and it was just fine. A balsa plane would have had much more damage..
I painted the wing botoms with Top-flite spray. It went on well.
Thanks again.
Thanks again.
#38
Thanks Ed for the good information.
Finally, has anybody actually installed a gear box in the Spectra? As I look at it, it is going to need some cutting of the fuse to fit it in. The T600 motor doesn't have much space around it.
#39
These three threads discuss the Spectra and Aspire. Many people have put gearboxes in them for better climbs.
http://www.rcuniverse.com/forum/m_3274520/tm.htm
http://www.rcgroups.com/forums/showthread.php?t=406132
http://www.wattflyer.com/forums/showthread.php?t=593
#40
Well I flew my Spectra a few weeks back, using the stock motor, T600 I thinnk, an Electrifly C35 ESC, and 11.1 v LiPo battery. I used the throttle travel limit to get the voltage back to 9.
It is a slug with this configuration. It does climb but doesn't set the world on fire doing so, so I guess I'll be going brushless soon. I have the motor, ESC and LiPo, so it's just a matter of the installation. Currently the batery is about as far back as it can go, under the servo tray, so with a very light brushless motor, I'll be able to balance it with battery location.
Nice to fly though; my first sail plane.
#41
http://www.maxxprod.com/mpi/mpi-262.html
#42
That looks like a good candidate. If you go with that motor, I would suggest the 1100 verson and go with an 11 or 12 inch prop. You will get better climbs than with the smaller prop recommended for the 1500 KV version.
Also, it has been shown that the stock motor, with a gearbox and a bigger prop will give much better climbs than when using the smaller prop on the direct drive speed 600 motor.
#43
Anybody still watching this thread? I just received my Spectra and the question I have is about the wing joiner. It came as a two piece aluminum dihedral brace with a balsa dihedral piece. Am I suppose to glue this together making a sandwich (aluminum, balsa, aluminum)? Thanks in advance.
#45
yeah, that's what I thought. They should really mention it somewhere like the addendum sheet they provide. Otherwise, I'm quite impressed with the quality of this ARF.
#46
I am new to electric gliders, but have a good knowledge of nitro cars. I just purchased a spectra a few months ago and have it up and running pretty good. I am interested in converting the plane to brushless and am looking for a good brushless motor that is a drop in replacement for the t-600 that came in the plane. I am still trying to understand all of the battery, motor, esc, agreements, so more explanation is better. Thanks for your help.
#47
I wish I could just get the stock ESC to work. No instructions, manual, or description of how it should work. Servos work, if I directly attach the battery to the motor it'll spin, but no action of the motor through the ESC. Think my ESC could be shot?
#48
OK
There is a safety built in to the ESC. Turn on the transmitter, with the throttle all the way back, then turn the plane on. Push the throttle to full then back to off. That turns the power "on" to the motor. It should spin after that.
#49
Well, I tried that, and it still didn't work. I even thought maybe the battery wasn't fully charged and tried re-charging, but no motor spin. It worked for a brief moment when I first wired it but never stayed on. Also originally there was a red led that lighted, now nothing. Now I can't even get it to do that. I'll try checking my battery charge again. I followed polarities. Frustrated.
#50
Tom,
What size battery pack are you using? If you tried a 3 cell lipo you may have fried the ESC. The recommendation for that ESC is 7 cell NiXX only.
AMAtoJB
This should help you with learning about electric flight.
> EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC FLIGHT
> http://www.rcuniverse.com/forum/m_7100376/tm.htm
As for a brushless to replace your current T-600, there are probably 100 motors that will work. What is your reason for the change? Motor worn out? Too mild a climb?
As you will read in the thread I posted, we size motors using a "watts/pound" forumula. I find that a target of about 60-80 watts/pound provides excellent climbs for sailplanes.
One of the factors will be how you plan to mount the motor. If you want to pull out the T-600 and drop in a brushless, the width of the fuselage will tell you how wide the motor can be. Outrunners have spinning cans, so they need to be mounted such that the outside of the motor can spin freely. Inrunners are typically used with gearboxes on sailplanes.
As you look at motors, look at motors that can take a 10-12" prop. This will give you a much better climb than the 8X4 typically used on a speed 600 motor.
If you are using NiCd packs, a switch to Lipos will save you a LOT of weight and that will make a huge difference.
Just some thoughts to get the juices running.
Finally here are some thread where this plane is discussed. You should find some listings of good motors as well as people who have made the conversion.
AMAtoJB
