Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Can I plug a 7.4 lipo directly into a receiver?
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 06-23-2008, 05:36 PM
Dr.Oates
Default Can I plug a 7.4 lipo directly into a receiver?
I have an old micro receiver that I am planning on using with a lipo. The receiver is an old JR R610M.. this will be placed in a 9 oz. DLG and I dont need an ESC.... so how do i go about plugging this thing in? I dont know much about the receivers voltage specs...so I am wondering about how to do this. I'd like to use my Parkzone 7.4 10C 800Mah battery, but it may weigh to much...still the questions remains.... even with a smaller 2S 270mah -2C lipo.... how do i plug it into the receiver?
Old 06-23-2008, 06:11 PM
SoarLA45
Default RE: Can I plug a 7.4 lipo directly into a receiver?
You either need to connect a micro ESC with BEC to the system or you ahve to use a power regulator. Power regulators are large and are made for giant scale planes where size is not a concern. Do not plug a LiPo directly into the receiver.
If you can find a micro transformer or regulator, use it, if not the Micro ESC will do the job well.
Old 06-23-2008, 09:31 PM
Dr.Oates
Thats what i wanted to know... thanks!
Old 06-23-2008, 09:32 PM
SoarLA45
Try using one of those cheap 5-8 amp ESCs...
Old 06-23-2008, 09:40 PM
SoarLA45
GWS sells very cheap ones on Tower
Old 06-24-2008, 07:33 AM
Dr.Oates
Thanks Zagiz, out of curiosity what is the voltage for most receivers...is it 4.7 or something close? Ill check into the Bec... i have a small Electrifly, but I got a feeling im gonna run into a weight issue with this. I just remeber back in the day, I would plug my nimh directly to the receiver, but of course the voltage was different.
Old 06-24-2008, 01:49 PM
SoarLA45
Receivers work on four cell reciever batteries made of NIMH or NICAD. Small ESCs dont weigh much BTW. The votage is 1.5 volts per cell x 4 so it is a six volt battery.
Old 06-24-2008, 03:49 PM
tmproff
tmproff's Avatar
Actually, each cell is 1.2 volts so a 4 cell will be 4.8 volts.
You can plug a 5 cell battery (6.0V) into your receiver and your servos will become stronger and quicker. I have a Giant Scale Yak that I use 2 cell Lipo's / BEC to power my receiver.
Old 06-24-2008, 04:36 PM
SoarLA45
Oh what a [email protected]$$ I am! Of course, reciever batteries are 4.8 not 6 volt.
Old 06-24-2008, 06:09 PM
aa2dd
there were some posts recently, a few weeks ago, about running a 2 cell LiPO directly into the receiver with no regulator. I tried it, and have been flying ever since, using 2 cell lipo with no regulator. For your information, take a voltage check of your 5 cell NIMH or nicad when you first charge it and start flying it. It is well above 6 volts. I seen an ad recently, for I believe, a HItec receiver, and it was rated at 8.4 volts.
Bruce
Old 06-25-2008, 05:36 PM
keiko
a four cell recieverpack will be "flat" when it's 4.8 volts,as will a car battery be flat when it is 12 volts....
I don't know too much about lipos,so I can't say how they are...
hope this was helpfull...
Old 06-26-2008, 08:49 AM
tmproff
tmproff's Avatar
I agree that a fully charged 5 cell battery will be over 6V, but it will only be in that state for a very short time. I am not so much worried about the receiver than I am about the servos being able to handle above 6V. I think it's a huge risk to plug a 2cell lipo directly into a standard receiver.
Old 06-26-2008, 12:21 PM
SoarLA45
Some Spektrum receivers have built in LiPo capability so you can use them on giant scale planes and they still deliver normal voltage to servos..
Old 07-01-2008, 06:40 PM
mred33
mred33's Avatar
ORIGINAL: keiko
A 4 cell NiCad will be 3.2 volts when flat, and 4.8 is nominal voltage. Nicads and NiMah's are the same, flat is .8 volts per cell. A LiPo cell is flat at 3 volts per cell. A 2 cell lipo may burn out a receiver and or the servos, so I would not do it. A fully charged 2 cell LiPo will read 8.4 volts and that is to much for most receivers and quite a few servos. You can use a UBEC or an ESC and get 5 volts out of either and no harm will come to your system, but don't try a 2 cell LiPo unless you like to see the smoke come out. By the way, 12 volts out of a car battery is nominal too. That is what you will read under load. That's why they call them 12 volt batteries.
Ed
Old 07-04-2008, 11:00 PM
trickydevil
Hyper flight in the uk do a small voltage regulator for dlg's.
[link]http://www.hyperflight.co.uk/products.asp?cat=Hyperflight+R%2FC+electric+%26+gl iders&subcat=Electronics[/link]
HtH
Richard
