Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
 Brushless Upgrade For GP Spectra??? >
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 04-03-2009, 04:25 PM
Default Brushless Upgrade For GP Spectra???
Greetings all,
I have a stock Spectra ARF which I have flown off and on for the past 4 years. I've finally decided I want to upgrade to a brushless powerplant.
Can anyone recommend an easy bolt on replacement for the Spectra???
Thanks in advance.
Mike
Old 04-03-2009, 09:27 PM
Default RE: Brushless Upgrade For GP Spectra???
The only way that I know of to do a "direct" replacement would be to use an in-runner. Take a little time and set it up for an out runner. That will allow you to swing a larger prop without having to use a gear box. Something like an E-Flight 10 with a 2-3 cell Lipo would give you plenty of power for a 2 meter like the Spectra. Also spend a couple extra bucks and take it to a folding prop. Less drag when not in use and less chance of breaking them on landing.
Old 04-12-2009, 09:39 AM
aeajr's Avatar
If you get rid of the NiCd pack you will drop a LOT of weight so I would suggest you plan that as part of your upgrade.
As far as a brushless motor, you can get an inrunner/greatbox combo or you can go to an outrunner. The the only thing wiht outrunners is you have to be mindful of the space inside the fuse for the spinning can. Some makes have long skinny designs. Others, like the Rimfires, have wide cans and may not clear.
Something in the 200 watt range should give you great climbs.
What is the width of the interior at the current motor mount location?
Old 04-12-2009, 10:13 AM
aeajr's Avatar
You might find it helpful to post in this thread:
http://www.rcuniverse.com/forum/m_27..._3/key_/tm.htm
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
