Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Advice needed on excessive wiring.
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 10-01-2009, 05:45 PM
Hoverglide
Default Advice needed on excessive wiring.
Hi all,
I am building a 2 ch epp glider, & want to keep the wiring to a minimum.
Basically I have a Futaba radio, 2x servo`s, 1x Nicad, 1x receiver, & a harness switch which has a cable attached for recharging the Nicad.
Is possible for me to just connect the nicad to the receiver when I am ready to fly, & manage without this harness switch cable, as I am struggling for room.
Many thanks,
Ian.
Old 10-01-2009, 06:36 PM
rcsoar4fun
My Feedback: (12)
Default RE: Advice needed on excessive wiring.
You can do that, but it can be a bit of work to plug and unplug. A little more elegant solution is to plug the battery into an aileron extension, it takes up less room but is easier to connect.
Old 10-02-2009, 08:48 AM
skeeter_ca
skeeter_ca's Avatar
Good tip rcsoar, Using a short extension will keep from stressing the pin connection at the receiver. and allow alittle room to stick your fingers in.
skeeter
Old 10-02-2009, 09:44 AM
Hoverglide
Hi again,
Thanks rcsoar4fun & skeeter, that seems to be the perfect fix, & saves me wearing out the reciever connections.
Thanks again.
Ian UK.
