RE: Scratch Designed/Built Sailplane
I got 90% of the v-tail done today, SWEET!
I decided to do things properly & use a symmetrical airfoil for the tail feathers. Flat stabs tend to stall sooner than those with an airfoil... stalling = bad. I printed a set of tail ribs & contact cemented them to the wood... http://www.scipie.com/rc/vee-gull/20120421_0005.jpg Used my scroll saw to rough-cut the ribs... http://www.scipie.com/rc/vee-gull/20120421_0011.jpg Finished up the rib shapes with a sanding block... http://www.scipie.com/rc/vee-gull/20120421_0015.jpg The notch in the ribs is to accommodate some carbon fiber reinforcing. I glued a small CF tube to the center spar, it should make the tail nice & rigid... http://www.scipie.com/rc/vee-gull/20120421_0018.jpg The root of the v-tail is made from some fairly dense 3/8" balsa, carved to the airfoil shape. It should give a nice solid foundation for the tail & hopefully make mounting everything to the tail boom a snap... http://www.scipie.com/rc/vee-gull/20120421_0027.jpg Looks like something that belongs on a jet... fun fun. I still need to add the strengthening gussets & do some sanding. Will pick that up tomorrow... http://www.scipie.com/rc/vee-gull/20120421_0031.jpg |
very nice build.. Which scroll saw are you using for cutting the ribs?
ORIGINAL: highfly3D very nice build.. Which scroll saw are you using for cutting the ribs? |
Why is it the last 10% takes 90% of the time?
So I started adding gussets to the v-tail. I carefully measured the required angle then set about making 32 of these little buggers... http://www.scipie.com/rc/vee-gull/20120422_0036.jpg Then I noticed, duh, I'd need different shaped gussets for different areas of the tail. The leading edge, for example, runs at a different angle to the ribs than at trailing edge. After a long groan I tossed most of them & set about cutting out a new set. Anyway here's a panel with the corrected gussets installed. Came out nice & strong & fairly light... http://www.scipie.com/rc/vee-gull/20120422_0053.jpg And now for the next time sucking issue... One of my ruddervators (love that word) annoyingly appears to have developed a moderate warp along its hinge line... http://www.scipie.com/rc/vee-gull/20120422_0045.jpg So back to my damp sponge trick, I saturated the wood then using a straight-edge as a guide, secured it to my workbench. I'll let it sit overnight, fingers crossed she'll be straightened out come morning... http://www.scipie.com/rc/vee-gull/20120422_0050.jpg |
Hey Nodd,
What is the worse warp you ha been able to fix with the sponge trick? |
<font size="-1"><font face="Verdana">Theoretically you could take a piece of balsa, bend it around so one end touches the other. Just add water, bend, let dry & repeat. Its pretty malleable stuff if you take your time. Steaming or heating in an oven are other wood bending techniques.</font></font>
I had a great session today, got a lot done. Best of all I'm not all grumpy like I was yesterday.
The warp in my ruddervator is better but I'm still not happy with it. Will give it another go with the damp sponge trick & see where that takes me... http://www.scipie.com/rc/vee-gull/20120423_0028.jpg So anyway, I'm not letting that issue slow me down. Time to make a V out of my tail... I needed to add a 55° bevel to each of my tail-feathers. I spent some time scratching my head, thinking up all sorts of crazy jigs & whatnot. In the end I decided to just get on with it & adjusted the table on my belt sander to 55° & went for it... http://www.scipie.com/rc/vee-gull/20120423_0029.jpg With very little fine tuning from the block sander, amazingly she went together at exactly 110°, SWEET!.. http://www.scipie.com/rc/vee-gull/20120423_0050.jpg Again with the head scratching, I needed a way to attach the v-tail to my CF tail-boom. Actually that's the easy part, I'm just going to fiberglass it around the tail-boom. The tricky part was finding a way to make sure the tail lines up straight. So here's what I came up with... I temporarily tacked a short section of scrap CF tube to the v-tail making sure it ran down the joint precisely. I then epoxied two small strips of plywood either side to just the tail, not the CF... http://www.scipie.com/rc/vee-gull/20120423_0052.jpg While that set I carved a few short slots in the very end of the tail-boom. The thinking here is that'll give the glue something to index & hopefully keep the tail from working loose & spinning on the shaft. I also roughed up the CF with some course sandpaper... http://www.scipie.com/rc/vee-gull/20120423_0054.jpg Next I mounted the wing center section to the fuselage & used a bunch of clamps to hold the wing perfectly level with my work bench... http://www.scipie.com/rc/vee-gull/20120423_0059.jpg Yet another use for the amazing Quick Grip clamp, love those things. Once I had the airframe squared up I removed the temporary CF tube from the tail then went ahead & epoxied the v-tail to the tail-boom. I used a ruler to check it was square with the bench, propped it up with a glue bottle & I'm leaving this puppy to set overnight... http://www.scipie.com/rc/vee-gull/20120423_0066.jpg Tomorrow I'll reinforce the tail joint with fiberglass. Feels great to finally get the tail on there. Another major milestone achieved, YIPPY! |
very good... this reminds me of the Kyosho Glider
Yeah she looks a little like the Kyosho, ONLYTOTALLYCOOLER! *grin* just kidding
Odds & Ends
No photos today. I didn't really do anything photo-worthy, just lots of odds & ends. Here's a quick list of what I got done... <ul>[*]Visited hobby shop & picked up nicknacks, control horns, pushrods etc[*]Finished fiber-glassing the v-tail to the tail-boom[*]Fixed the warped ruddervator by sanding it straight[*]Trimmed to length all the control surfaces[*]Installed the two ruddervator pushrods[*]Did more sanding here & there[/list]Movie night tomorrow so not sure how much I'll get done but I believe I've arrived at yet another milestone. It might finally be time to break out the Ultracoat, WOOHOO! |
ORIGINAL: Nodd Odds & Ends No photos today. I didn't really do anything photo-worthy, just lots of odds & ends. Here's a quick list of what I got done... <ul>[*]Visited hobby shop & picked up nicknacks, control horns, pushrods etc[*]Finished fiber-glassing the v-tail to the tail-boom[*]Fixed the warped ruddervator by sanding it straight[*]Trimmed to length all the control surfaces[*]Installed the two ruddervator pushrods[*]Did more sanding here & there[/list]Movie night tomorrow so not sure how much I'll get done but I believe I've arrived at yet another milestone. It might finally be time to break out the Ultracoat, WOOHOO! |
Here's a detail of how the tail was fiber-glassed to the tail-boom...
http://www.scipie.com/rc/vee-gull/20120426_0003.jpg Added some stylish wingtips... http://www.scipie.com/rc/vee-gull/20120426_0006.jpg Bare-Bones And with that the airframe is complete, wO0t! Before she's covered I thought I'd take a few bare-bones photos to help celebrate... http://www.scipie.com/rc/vee-gull/20120426_0022.jpg http://www.scipie.com/rc/vee-gull/20120426_0029.jpg http://www.scipie.com/rc/vee-gull/20120426_0033.jpg http://www.scipie.com/rc/vee-gull/20120426_0041.jpg http://www.scipie.com/rc/vee-gull/20120426_0043.jpg http://www.scipie.com/rc/vee-gull/20120426_0050.jpg Feels great to have gotten this far. |
I'm beginning to get all goose pimply thinking about the test flight post.
It's coming along great. And you've done a really fine job of doing a comprehensive build thread. |
ORIGINAL: BMatthews I'm beginning to get all goose pimply thinking about the test flight post. It's coming along great. And you've done a really fine job of doing a comprehensive build thread. AMEN! |
Thanks guys. Yeah I'm not sure which I've spent more time on, the plane or this silly build thread LOL
Wrapping Things Up Well we can't have this glider parading around naked, time to do some covering. I chose to use Hanger 9 Ultracoat as I've worked with it before & like the way it applies. Low temperature to activate the adhesive then switch to higher temp to do the shrink-wrapping. Its also pretty forgiving & most wrinkles can be eliminated with some heat... http://www.scipie.com/rc/vee-gull/20120426_0070.jpg I wanted to show off the built up structure so I'm using transparent red on the open areas & opaque white everywhere else... http://www.scipie.com/rc/vee-gull/20120426_0077.jpg Before I got too far into the wing covering I performed another balance check... http://www.scipie.com/rc/vee-gull/20120427_0089.jpg I centered the wing on my balance stand & added weight to the light side... http://www.scipie.com/rc/vee-gull/20120427_0090.jpg Three small nails on the left wingtip & she balances perfectly. There is a school of though that says its a mistake to add weight at the tips as this adds unwanted mass way out on the ends of the wing, not where you want it. Its often better to add weight further in & keep the tips as light as possible. The down side is you need more weight to achieve the same result. As my wing was already balanced fairly close & needed just a few grams I felt it was fine to just stick the nails into the end of the wing... http://www.scipie.com/rc/vee-gull/20120427_0096.jpg If you use nails for weight you should pre-drill the holes. Don't go hammering away at your wingtips, bad idea. Once in place a drop of CA glued keeps them secure... http://www.scipie.com/rc/vee-gull/20120427_0101.jpg Here's my home-brewed CG balance stand. Simple & because its in two pieces it fits just about any airplane. Note the spiffy rubber tips to keep things from slipping while balancing... http://www.scipie.com/rc/vee-gull/20120427_0099.jpg Anyway with the wing balanced I covered over the nail holes & turned my attention to the v-tail... http://www.scipie.com/rc/vee-gull/20120428_0081.jpg I'm trying something new on this model. I usually use CA hinges but I noticed one of my ARF gliders uses just the covering its self as a hinge joint. The result is a gap-less joint that's fairly sturdy & doesn't seem to bind at all. If my ruddervators start to fall off in a month or so I guess its back to CA hinges but my other glider has been around for years & no signs of hinge fatigue yet. So I thought I'd give it a try. Here's how my hinges are laid out... http://www.scipie.com/rc/vee-gull/ultracoat-hinge.jpg From the top at least the joint looks totally seamless. Obviously there's a small slot on the under-side to allow the control surface to move downwards but aerodynamically its pretty clean. I like... http://www.scipie.com/rc/vee-gull/20120428_0085.jpg Well that's enough for today. I'll tackle the rest tomorrow... http://www.scipie.com/rc/vee-gull/20120428_0086.jpg |
Awesome... great superb..
This "silly build thread" is the most educational thing I've seen here.
On the other hand, it's depressing to see how much work I have to do on my covering technique. I'd better get another build started for practice. |
I prefer using hinges and thenusing either clear tape or covering to hide the gap. On large aircraft I round the moveable surface and then make a matching concave slot in the trailing edge of the mating surface.
The plastic covering films work fine on slower flying models even up to 3 meter span gliders. For a faster powered or contest sailplane where high speeds will be regularly used then I like the security of proper hinge with some sort of sealing film or tape. In the case of a sport glider such as what Nodd is doing here I'd be using the film hinges as well. Simple, clean, and workable for a model such as this.
Nodd, the first sign of any possible "hinge distress" will tend to show up on the longer hinge lines such as on the ailerons. This can occur if the wings flex up under load and you're flexing the ailerons at the same time. So keep an eye on all the hinges but especially the ailerons. |
1 Attachment(s)
I'm trying something new on this model. I usually use CA hinges but I noticed one of my ARF gliders uses just the covering its self as a hinge joint. The result is a gap-less joint that's fairly sturdy & doesn't seem to bind at all. If my ruddervators start to fall off in a month or so I guess its back to CA hinges but my other glider has been around for years & no signs of hinge fatigue yet. So I thought I'd give it a try. Here's how my hinges are laid out... Now, if it makes you feel any better.....I have been using that "covering hinge" method for quite a few years. When done properly it is a superb, trouble free system. To reiterate what Bruce said, it is best on slower aircraft such as gliders and park flyers, and you will have no problems with yours at all. Now, just to show you how well they can stand up even on an aircraft that is able to fly a bit faster and put more loads on the controls................ This nice green airplane does not have a single "proper hinge" anywhere. Every control, ailerons, elevator, and rudder, are ALL done with the exact system you show above in your diagram. After 1 full season of hard flying, includinga bunch of glider towing. |
Nice Rhall999! Is that a Hoerner wingtip you have on the green airplane? What are the specs?
1 Attachment(s)
Sorry Nodd, we are heading slightly off topic for a couple minuteshttp://www.rcuniverse.com/forum/js/f...ssed_smile.gif
Nice Rhall999! Is that a Hoerner wingtip you have on the green airplane? What are the specs? Anyhow......back on topic..............Ihave a question for Nodd, what are you going to call that beauty that you built. (Maybe you already said, but I might have missed it) |
Nice Kadet. Yeah some of the guys I fly with are into the aerotow thing. I'm planning to attend the New England Aerotow 2012 next month. Trying to get my 4m Discus ready for that. Will probably bring this plane with me too as they allow motor-gliders. Should be fun.
ORIGINAL: rhall999 ...Ihave a question for Nodd, what are you going to call that beauty that you built. (Maybe you already said, but I might have missed it)... |
ORIGINAL: BMatthews ...Nodd, the first sign of any possible "hinge distress" will tend to show up on the longer hinge lines such as on the ailerons. This can occur if the wings flex up under load and you're flexing the ailerons at the same time. So keep an eye on all the hinges but especially the ailerons... |
An excellent question which unfortunatly I have no answer for just yet. I do have a few ideas though. We'll see. Nice Kadet. Yeah some of the guys I fly with are into the aerotow thing. I'm planning to attend the New England Aerotow 2012 next month. Trying to get my 4m Discus ready for that. Will probably bring this plane with me too as they allow motor-gliders. Should be fun. |
