Bagging wings - A resource thread
I am not a builder but I have a lot of respect for those who like to build.
I have been preparing a section of my weekly newsletter on Bagging Wings. There will be a presentation at our club on the topic at the next meeting. I think I pulled together some good resources so I am going to post them here for those who might be interested. And I encourage anyone who knows hot to bag wings or who has question about bagging wings to post in this thread. Maybe we can get a good exchange going. If my club is interested we might start a "one design" group build around a bagged wing project. If it happens I will let you know and share a link to the discussion. RESOURCES BAGGED WING GLIDERS – THE LOW COST WAY TO BUILD COMPETITIVE TD, ALES and HAND LAUNCHED GLIDERS Many of the gliders flown at the ESL contests at our field are bagged wing designs. Learning about bagging wings will open up a whole new world of options for you. You can make DLGs, larger models, winched gliders and electric gliders that look and fly very much like the high end molded wing gliders. First you cut the foam cores Hot wire cutting foam cores https://www.youtube.com/watch?v=-sd0c7Y1XqE https://www.youtube.com/watch?v=jZkTCeoN79M Hot wire kit review http://www.cstsales.com/tekoa_hot_wire.html http://www.rcgroups.com/forums/showthread.php?t=971230 Custom cut foam cores if you don’t want to cut your own http://www.clm-pro.com/cnc-cutting-services Make your own foam cutter http://www.charlesriverrc.org/articl...foamcutter.htm Making foam cutting templates https://www.youtube.com/watch?v=O8M91NlsxPE Then they go in the bag Vacuum Bagging Overview video He is not making a wing, he is making a part on a mold This could be used to make 1/2 of a fuselage The process is similar for wings as you will see in the other videos https://www.youtube.com/watch?v=5jSwx_EkJgM Wing bagging videos – to give you a flavor of what it takes: Bagging a DLG wing, start to finish https://www.youtube.com/watch?v=tW3fEWBZGrU Bagging DLG wings https://www.youtube.com/watch?v=oFWuorRZPnQ Bagging a scale glider wing https://www.youtube.com/watch?v=ywPe3eqBofE Telos building thread with $10 VACUUM BAGGING SYSTEM Tutorial!!! http://www.rcgroups.com/forums/showthread.php?t=966524 Vacuum Bagging Systems http://www.cstsales.com/vacuum_bagging.html http://www.cstsales.com/basic_vacbag.html Vacuum bagging with a vacuum sealing food saver May not be good enough to build a Supra but it might be good to give the process a try if you have one of these. http://www.rcgroups.com/forums/showthread.php?t=186029 Nice write-ups and photos of building a foam core wing for bagging. May fill in some details that you don’t pick up from the videos http://www.cstsales.com/vac_wing.html http://www.favonius.com/soaring/bagging/bagging.htm http://www.favonius.com/soaring/bagging/tail_end.htm http://www.pilotsguide.com/rc/vacbag.shtml Instructional Videos on making bagged wings Beginners Guide to Cutting and Bagging Foam Wings http://www.tailwindgliders.com/Sales.html Phil Barnes - Vacuum bagging made easy – video set (I have this set) This is based on the stressed skin approach, as I recall http://www.rcgroups.com/forums/showthread.php?t=190214 I confirmed that the video is still available even though a couple of the preview links on the page don’t work. You can order the video here. http://home.paonline.com/hayman/PAGE2.htm OK, you are interested. What can you build? Here are some examples. Mark Drela competition glider designs that are based on bagged wing construction Supra – 3.4 meter glider http://charlesriverrc.org/articles/supra/supra.htm Aegea 2 – 2 Meter Glider http://charlesriverrc.org/articles/a...la_aegea2m.htm Super Gee 2 – DLG http://charlesriverrc.org/articles/s...SuperGeeII.htm You can buy the Super Gee 2 foam cutting templates and the boom here: http://www.mountainmodels.com/produc...roducts_id=192 Lost foam method of making composite parts. You could use this method to make your own pod/fuselage http://www.rcgroups.com/forums/showthread.php?t=188980 Glider design discussion based on a bagged wing Supra. This conversation goes back to 2011 and is still active today. If you want to read a bit about how people take an existing design, the Supra, and modify it, this is an interesting discussion. http://www.rcgroups.com/forums/showthread.php?t=1528685 OK, You made the wings. What about the rest of the parts? You can make your own fuselage/pod or you can buy one These guys sell pods, booms and v mounts http://www.clm-pro.com/pods http://www.rcgroups.com/forums/showthread.php?t=1832907 Tail Booms https://goodwinds.com/catalogsearch/result/?q=Tail+Boom If you want to design and build your own – these are for the composite building junkie DEPARTMENT OF DEFENSE HANDBOOK - COMPOSITE MATERIALS HANDBOOK http://www.library.ucdavis.edu/dept/.../HDBK17-3F.pdf Design Software XFLR5 - Planform and airfoil integrated design http://www.xflr5.com/xflr5.htm Profili - Airfoil performance and plotting software http://www.profili2.com/eng/default.htm Plane Geometry - Design parameters in Excel spreadsheet. Plug in the measured parameters of your model and back out the performance properties, or vise-versa. Great for scaling up planes or making small changes in design but keeping the flight characteristics the same http://www.envisiondesignusa.com/evd..._Overview.html Linkage Design - calculate you linkage layouts, calculate torques and moment arms for your servos, etc http://www.envisiondesignusa.com/evd..._Overview.html ========================== PLEASE POST YOUR QUESTONS OR INPUT. TELL US OF YOU EXPERINCE BUILDING BAGGED WING GLIDERS. SHARE YOUR TIPS AND TRICKS, PHOTOS AND VIDEOS. |
WOW! Thank you for putting all these resources in one spot. I am thinking about getting started building my own and I bet you've just saved me about a month of research!
So, all you wing baggers! Let's get some input, some photos, some tips and tricks.
Feel free to add your wisdom, your build thread links, your how to tips. |
Anyone in PA, NJ or NY who can do a wing vacuum bagging for me?
I just do not have a space for that and need to find someone in a area who has a setup to do it. I googled a lot - did not find anybody. I have a foam wing cutout with core. I will prep the wing for bagging and either come-up or mail it to you. I live in Poconos, PA, Stroudsburg area. Would appreciate any help or point to the right direction. Cheers, Mark |
