RCU Forums
-   RC Gliders, Sailplanes and Slope Soaring (https://www.rcuniverse.com/forum/rc-gliders-sailplanes-slope-soaring-112/)
-   -   Thrust Angle for an Up & Go (https://www.rcuniverse.com/forum/rc-gliders-sailplanes-slope-soaring-112/353400-thrust-angle-up-go.html)
wildblueyawner 11-06-2002 09:09 PM
Given the thrust line of an Up & Go high above a glider's vertical CG location, a nose-down pitching moment will be created, stronger than what a conventionally-mounted motor would generate.
Will increasing the downthrust angle effectively increase the angle of attack, in order to compensate for the pitching moment?
MTT 11-06-2002 11:13 PM
No, you will have to compensate with up elevator, either manually or through a mixer.
Also see thread : "Giant sailplanes" in this forum, towards the end of the thread.
Michael
talybont 11-07-2002 07:32 AM
Hi,
we had the best results with the thrustaxis pointing at the elevator nose. You will always have to pull a little bit while power flight.
MfG,
Armin
