Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 How Tight Should Blades Be? >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 03-09-2011, 01:41 PM
Default How Tight Should Blades Be?
One other noob question for you veterans.
How tight should my main/rotor blades be? Should they be rigid or loose?
Old 03-09-2011, 02:50 PM
Default RE: How Tight Should Blades Be?
I was told that the blades should be tight enough so that when you hold the heli sideways that they will not slip, but loose enough so you can turn them in the blade holders (so that they can adjust themselves during spool-up. After a while you will develop a "feel" for what is right and won't be having to turn your heli sideways.
Mack
Old 03-09-2011, 07:40 PM
Ok, that makes sense. When the blades come to a stop should there be movement? I am just trying to get a better understanding of how it should be.
Thank you for your response.
Old 03-10-2011, 05:52 AM
Rafael23cc's Avatar
ORIGINAL: hagosrush
No.
The technique for testing the blades "tightness" goes like this:
Hold the helicopter sideways, holding the head horizontal to the ground. The blades should not move on the grips. Give the heli a sharp shake, and the blades should fold down about half way, preferably the same distance.
Rafael
Old 03-10-2011, 06:27 AM
ah ok, I will try that this morning. Thank you Rafael.
Old 03-10-2011, 01:19 PM
Thank you very much Rafael, my blades are secure and the heli is does shake out of control when it starts up or slows down.
Old 03-10-2011, 06:37 PM
phillyD's Avatar
Hey Bro
Make sure all the frame screws are done up, blades need balancing, main shaft or feathering shaft bent or skids are slack. Spool up the heli without the main blades andsee if it still happens.
Cheers
Old 03-11-2011, 06:25 AM
Rafael23cc's Avatar
ORIGINAL: phillyD
Hey Bro
Make sure all the frame screws are done up, blades need balancing, main shaft or feathering shaft bent or skids are slack. Spool up the heli without the main blades and see if it still happens.
Cheers
Please, NEVER suggest to anyone to spool up a helicopter without the load of the blades.
ORIGINAL: hagosrush
The blades might be a little too tight. You might have to power thru the shaking to see if it will smooth out as the rpm go up. DO NOT spool up without blades, but do follow phillyD suggestions in checking everything else on the helicopter. I had a violent shaking in one of my helicopters a few seasons ago, and it ended up being the top two screws on the frame (the ones that hold the top bearing of the main shaft) were loose and letting the main shaft wobble.
Rafael
Old 03-11-2011, 06:29 AM
BarracudaHockey's Avatar
What Rafael said
Old 03-11-2011, 06:31 AM
ORIGINAL: Rafael23cc
ORIGINAL: phillyD
Hey Bro
Cheers
Rafael
Being the new guy, may I ask why it is suggested to never do that?
Old 03-11-2011, 06:35 AM
Rafael23cc's Avatar
the easy answer would be that spooling up the heli without blades is the quickest way to burn up your engine. Not to mention that the helicopter gearing is designed to spin up a certain "weight" and if you remove that weight, you are for certain to overspeed the components potentially causing catastrophic failure.
Sorry, I was editing my previous post to add information and the thread cntinued it's path without me.
Rafael
Old 03-11-2011, 06:45 AM
Well Ill just be a monkeys uncle if I am not learning new things every ten seconds on this forum.
Old 12-08-2011, 03:39 AM
Yes, soaking it all up...Thank you, guys.
Old 12-09-2011, 06:32 PM
Yes just like Rafael pointed out. The blades should not be pullled by gravity alonebut must fall with a quick nudge. That is typical for a 450 and lower classes, however the bigger the bird the harder nudge needed to deflect them.
Old 12-15-2011, 03:26 PM
Should the tail blades be set the same way?
Old 12-15-2011, 06:01 PM
No, the tail blades should be loose given that they spin two or three times faster than the main head.
Tails however, are a bit more forgiving, shafts don't bend as easily and tail vibration or one-way
yawsets in if it's really messed up.
Hope this helps.
Old 12-16-2011, 01:41 PM
yeah umm if you were going to see if the wobble is there without the blades you wouldnt just pin it to full throttle lmao u will see it in the first 5 seconds even just going up slow i would say dont do it because the birdie will spin around from tail  but there again u can hold it to the floor and slowly spool it up and chances are you wont burn a motor but hey what do i know just my 2cents.
Old 12-17-2011, 08:35 PM
phillyD's Avatar
Ok Sirs
All are correct. bad word usage on my part.."spool up" you would just get the head to turn at a slow speed to see if the wobble appears. If it does it might be the shaft or bad main shaft bearings. if it doesthis with the blade, slack blades in grips, bent feathering shaft or I know someone whose blade grip bearings were bad.
Old 12-18-2011, 04:46 AM
i just learned something new as well. my Esky manual came witha loose page for the transmitter that"very strongly" recommends removing the blades before powering up the first time". i didnt do this out of fearfor what it would do to the assembly, and now i know! thanks for the warning
Old 12-18-2011, 07:07 AM
I powered my honeybee up without blades and it was fine. I didn't power it all the way up just enough to check for vibration. Mine recommended the same procedure.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
