CCW spin
CCW spin
I crashed my Ufly yesterday, and broke the stabilizer bar, and both blades. I changed the bar and both blades, and fired it up. Now the heli spins counterclockwise no matter how much counter I give it on the rudder stick (happens both on the ground and after lift off). The tail rotor blades change pitch in both directions as I move the rudder control, and the blades spin in proportion to the main blades It appears). Do you have any idea what the problem would be. I would really like to get flying again.
Thanks if you can help.
skyjacker
skyjacker
BC, CANADA
RE: CCW spin
Sorry, but I have never heard of a "Ufly". What is it and who makes it?
I would suggest that you check with the shop you bought it from. They should be able to help you.
