Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
Reload this Page >
Exceed G2 Raptor Help....
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 05-04-2011, 10:56 AM
hvhooch
Default Exceed G2 Raptor Help....
Hello All, I am a bit new to the 6 channel series helicopters and decided that the Exceed G2 would be a good start. I got my G2 and was fine out of the box. Was practicing lightly hovering and turning using training kit..... I took my eyes of the G2 for a spilt second and it took off side ways and I freaked out......LOL. I killed the power but still broke the main blades and bent the main blade shaft and bent the flybar....I replaced the parts and powered it up to before it gets off the ground it spins counter clockwise...???? I then held the the tail rotor with right hand and tried to turn the main rotor clockwise......It did turn clockwise while the tail did not move....I think that the tail rotor belt main gear is stripped....I read alot on this subject anf that is what I have been seeing.....CCW movement after main rotor strike in crash......... Also I may have changed the settings in the transmitter...does anyone no what the settings are...it is a walkera 2.4 GHZ 2602 transmitter I have the New DS Gyro and the settings are Normal & Reverse......... Ok there you have it....can someone help me with this.....I am going to disassemble Johhny 5, thats what I named the G2...LOL anyway Johhny is going to be broken down and I will order the Tail rotor main gears, frnt and back...this should take care of the CCW spin.....I hope........ But I still need help with the Trans. settings........
Old 05-04-2011, 04:14 PM
drobin
Default RE: Exceed G2 Raptor Help....
I had a G2 and found the tail belt is twisted when you have a ccw spin.If you check the tail blades, you will see they are turning backwards.The blades have to turn from the front of the helicopter up toward the back.
To get the mail shaft out, make sure you loosened or removed the set screws that hold the main shaft to the gear. I think there are 2 of them. I than took a punch or small phillips screw driver, what ever you have the is slightly smaller than the shaft and knock the shaft out from the bottom up.
Old 05-04-2011, 08:15 PM
hvhooch
Thanks for that info.........I have taken my G2 apart waiting for parts......I am replacing the tail rotor main gears, front and back.....I will make sure that the belt is installed correctly and with the right rension. thanks for the heads up.....
