Teach me about heli motors, please
OH
http://www.hobbyking.com/hobbyking/s...ter_Motor.html < fixed link
I ordered two of these for project I'll be working on. What is the distance between mounting bolt centers? Same as a typical brushless car motor I hope.
Also what size is this considered? 450, 500?
One more question, can you rotate them in reverse?
I know nothing about heli motors (except they're outrunners) so any help would be appreciated.
OH
RE: Teach me about heli motors, please
Trying again... If it doesn't work,here are the specs from the page:
Turnigy 3025-850kv 1300w Helicopter Motor
Specifications:
RPM/v: 850kv
Max RPM: 18800
No load current: 2.4A
Max Current: 74amp
Max Watts: 1300w
Thrust: 1440gram
Voltage: 22.2v (6s)
Diameter of shaft: 5mm
Weight: 182g
ESC: 80A
Kv (rpm/v) 850
Weight (g) 182
Max Current (A) 74
Resistance (mh)
Max Voltage (V) 22
Power(W) 1300
Shaft A (mm) 5
Length B (mm) 50
Diameter C (mm) 37
Can Length D (mm) 28
Total Length E (mm) 70
Specifications:
RPM/v: 850kv
Max RPM: 18800
Max Current: 74amp
Max Watts: 1300w
Thrust: 1440gram
Voltage: 22.2v (6s)
Weight: 182g
ESC: 80A
Kv (rpm/v) 850
Weight (g) 182
Max Current (A) 74
Resistance (mh)
Max Voltage (V) 22
Power(W) 1300
Shaft A (mm) 5
Length B (mm) 50
Diameter C (mm) 37
I know enough about electrics to get me in trouble... so take this with a grain of salt. I'm sure more knowledgeable people will jump in shortly....
Based on the rated voltage (22.2v / 6S), I'd venture to say that the motor is more suited for a 550 or a 600 size helicopter. Can you reverse the rotation? Yes, there are two ways of doing it. You either program the ESC, or swap out 2 of the 3 cables providing power to the motor. And last, I would expect the bolt pattern to be similar to similarly sized motors. As far as I know, there is no standarization here. Different sized motors have different bolt patterns.
I hope I helped a bit.
Rafael
Rafael
