Helicopter Screw help,
Hello guys, i'm having problem with a screw on top rotor of mini helicopter f1 series. I will attach a video.. Thanks
https://youtu.be/eXg6X1muhT0
I can't see the top of the shaft but there should be either a hole through the shaft or a notch cut into it. If it's a hole then the top rotor head needs to be positioned so the screw can pass through the hole when tightened.
If it is a notch then the head must be positioned so the screw can seat itself in the notch when tightened to keep the head on and make it rotate with the shaft.
