RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Throttle/Pitch curves
Old 08-28-2004, 10:07 PM
nmtr13
Default Throttle/Pitch curves
What are good throttle/pitch curves to use for hovering? I am currently using 7,28,50,75,100 for throttle and 0,25,50,70,100 for pitch and im not getting into a hover until im almost full throttle, does that sound right??
John
Old 08-28-2004, 10:39 PM
vallon
Default RE: Throttle/Pitch curves
Wow sounds like you are having a similar problem like me. You are not getting enough head speed of blades. I can tell you that much. I know only one thing. You may want to adjust your neadle valve and speed valve. That is what I am experimenting with now. My helicopter right now will start to hover at about 2 to 3 clicks past mid stick. I can bring it up hight in the air, well I have never really tryied that but I think I can. It just is not getting enough speed, even though I have my pitch and throttle curves set for hover. It's like sometimes my engine gets too hot or something and I don't have enough power to get off the ground. My pitch curves are set at 15, 43, 63, 77, 85. I don't know if this works for others, but this makes for more ease to me. This setting makes the pitch easier to me so that the heli does not shoot up in the air. It just eases up. But this is not the power loss I am talking about. Lets see what someone else might say how to fix your problem. If your servo is hooked up right and the engine is openning and closing propperly sounds like it could just be the valves. Try that.
Old 08-28-2004, 10:43 PM
pilot77
what pitch are u running on the blades ?? did u use a picth gauge? also what blades? if all of these are in good order with the correct blades umm id say its engine tuning
nmtr13
Yea i dont think im getting enough head speed because when i see vids of other raptors there getting way more speed than me. I think thats also the reason why my heli shakes and wobbles when i set it down. How do i get more head speed?
John
Old 08-28-2004, 10:45 PM
nmtr13
If your talking to me then no i didnt use a pitch gauge i used the one on the heli, im using wood blades.
John
Old 08-28-2004, 10:46 PM
pilot77
well its not your throttle curve coz thats in good order by the looks.. errm id say first establish if teh engine is cool or hot, id bet a million bucks your too rich. but stick your fionger on the backplate after sppol up i doubt youyr to lean. thouigh u;ll be too rich . which mean u have to adjust your needles. ummm what engien and muffler?? and where r the needles now?
Old 08-28-2004, 10:47 PM
pilot77
ok if u didn;t use a picth gauge the heli is a rappy?? that shoudl be okay but u really shoudl grab a pitch gauge its more accurate ,but the onboard one will do for starters
Old 08-28-2004, 10:48 PM
pilot77
sorry i should have read properly u have a raptor.
Old 08-28-2004, 10:49 PM
nmtr13
I was running a tuned pipe but switched to a Mac because the pipe wasnt secure and was vibrating, i have the stock muffler but the holes dont match up. Your right i am too rich because the last time i tried to fly it the engine bogged. The engine is an OS32. Ill check to see where my needle is now.
John
Old 08-28-2004, 10:51 PM
pilot77
Also touching on what Vallon said,. all this is assuming taht u have the throttle linkage set up properly?
nmtr13
Ok um my needle is actually only a half turn out, i dont know if i messed with it or i flew it like that, would that be the problem?
John
Yes the throttle is fine.
Old 08-28-2004, 10:53 PM
pilot77
If u r running rich thats easy to fix leave the idel screw factoryu set and adjust the main in a few clicks be really careful though , obvouusly if its a new angien u still wan tto run it on the rich side. just not so rich rtaht it won;t lift off
Old 08-28-2004, 10:54 PM
nmtr13
Its not new i got it used. Isnt a half turn out way too lean?
Old 08-28-2004, 10:56 PM
pilot77
is the motor new?? 1/2 a turn sounds way to lean. not rich
Old 08-28-2004, 10:59 PM
pilot77
yeps lean.. . put it to 1 or 1 1/2 out and try again if its hoplesssly rich this time and is worse then that problem is out of my league .
try a post on Runryder always peopel there to lend a hand
Old 08-28-2004, 11:00 PM
nmtr13
Ok thanks.
Old 08-28-2004, 11:03 PM
pilot77
Nmtr Good luck hope u get it sorted
