RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
lama v4 problems
Old 03-24-2008, 05:03 PM
wat/can/i/do/guy
Default lama v4 problems
i have my lama and i'll take off and it will be really wobbly in the air. a guy told me it was a bent shaft and i just replaced my inner shaft for a diff reson and it was fine then it got all wobbly was the guy right or wrong becuase i cant test it because he sold me the right shaft outter shaft but it was a cm to short.
wats wrong
Old 03-25-2008, 12:30 AM
paulospilot
Default RE: lama v4 problems
Gday mate welcome to the forum.
It sounds like your shaft is still bent somewhere or your blade tracking is way out.Maybey even the flybar rod needs a
look at.Does it wobble around in circles or shake in one spot?
Sorry i cant be of more help but hopefully someone with a bit more know-how can help...good luck
Oh have you had it for long?I have a v3 and love it
Old 03-25-2008, 06:11 PM
wat/can/i/do/guy
i brough it to the hobby store and he look at it and said it was shaft. he was right. i put the new shaftin yesterday, but my swash plate got all messed up idk wat happened, but ill try to get a picture up.
thanks for the help
Old 03-29-2008, 03:45 PM
mr. ilikehelp
hi daniel
Old 03-29-2008, 03:49 PM
wat/can/i/do/guy
hi james
Old 04-01-2008, 07:47 PM
wat/can/i/do/guy
i have another question. how much throttle do i put on my lift when i go into forward flight?
Old 04-02-2008, 04:50 PM
mr. ilikehelp
all the way forward
Old 04-03-2008, 12:24 PM
wat/can/i/do/guy
how much throttle on the lift stick
Old 04-03-2008, 12:42 PM
Bugzilla
Bugzilla's Avatar
Enough to keep it at the same altitude but not so much that it climbs, not so little that it decends, and more than it takes for a hover.
Old 04-03-2008, 03:09 PM
wat/can/i/do/guy
thanks so you just have to feell it
Old 04-15-2008, 03:31 PM
mr. ilikehelp
no just goo all the way then take ur rite stick go forward until the heli stops accending but isnt decending
Old 04-15-2008, 06:04 PM
Arnoldj1979
I would say you just have to feel for it. I''ve had my LamaV4 for a couple months. If your in a level hover, you can gently give right thumb up and counter gently with left thumb up until your blades are at maximum pitch and you can''t go forward any faster. If you give full left thumb you''ll notice she''ll out throttle your pitch and climb (mine will climb with a vengeance at full throttle, quickly even at full forward pitch) Keep in mind you will constantly be adjusting your rudder to keep it going straight. It''s not as much thumb work as an FP, but it''s thumbwork nontheless. Mine has taken a beating, I recommend upgrading it to aluminum rotor head, swashplate etc and throw some Extreme blades on her, much better than the stock stuff that you''ll end up breaking alot. Mine flies around the gym like a beast, and can take a beating.
