Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
Reload this Page >
WFLY RADIO SYSTEM any1 ever use this brand
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 11-30-2008, 03:11 PM
dude7422
Default WFLY RADIO SYSTEM any1 ever use this brand
hay all wfly radio systems what do you know about them any one. thinking of one for my low buck heli
http://www.flixxy.com/jet-man.htm << this guy gives new meaning to jetman and i posted this like 3years ago but could not find lol
The main functions are as follows:
Pitch Zero Trim (PZT).
Pitch Length Trim (PLT).
Be used for CCPM helicopter, airplane,car,boat.Standard 6 channel output.
Compatible with simulation softwares.
Channel 1,2,3,4,6 reverse switch
CCPM helicopter pitch reverse
CCPM state, aileron reverse switch
CCPM state, elevator reverse switch
Normal flying and 3D flying.The transmitter will alarms if it is turned on in a Idle-up state, and no output.
Dual rate
Throttle hold
Gyro Sensitivity adjust
Idle-up throttle adjust
Sound-and-light indicator for low power: When the battery Volatage is below 8.8V, the power indicator light 1S/1S glitters and buzzes.When it is below 8.3V, the power indicator light 0.5S/1S glitters and buzzes at the same time.
ID:	1081528   Click image for larger version
Old 11-30-2008, 05:01 PM
jerrymac
Default RE: WFLY RADIO SYSTEM any1 ever use this brand
If you are looking for a low cost radio you might also want to look at this. It is 2.4gh and comes with a duel reciever for $49.99 and free shipping. It is the radio system that came with my Blackhawk 450 and seems to work pretty good for a low buck system. I have never ordered from this supplier though, so I can't tell you anything about them.
http://www.snhobbies.com/product_inf...roducts_id=358
Old 12-07-2008, 10:42 AM
dude7422
jmac that sn hobbies has a bad rep on rc u from what i see. [sm=shades_smile.gif] so does xheli and i think they are fine some people post bad reports about web sites just to get you to shop else where that radio looks to simple
http://www.snhobbies.com/product_inf...roducts_id=407 now this radio looks nice
Old 12-08-2008, 12:10 AM
rotorbreaker
dude I agree with you. Other people in this forum pretending to be buyers but actually they are retailers who wants to get you shop from them. The Art-Tech 2.4G is ok but not programmable but the FS 2.4g for 49.95 is programmable. I bought both radio and they are very good.
Old 12-09-2008, 05:05 PM
dude7422
rotorbreaker the programable radio what and how can you program it hope you know
Old 12-17-2008, 05:57 PM
one thumb
Dude.
Check SN Hobbies post
one thumb
Old 12-17-2008, 10:08 PM
rotorbreaker
Hi dude,
You need to install the program utility that comes with the radio then connect the USB cable to the computer and transmitter. Once the program is intalled and running you can set the pitch curve, throttla curves, sub-trim, and mixing. Did you need a program for 450 size helis? I got T-REX 450 with 2.4Ghz radio I got from SN.
Old 12-18-2008, 04:58 PM
dude7422
hay thanks for all the help still looking for a good radio that is on sale i have bad luck with cheap electronics
but good luck with other cheap parts go fig.
This is the Futaba 7C 2.4GHz Helicopter Radio System with the R607FS FASST 7-Channel Receiver, and four S3152 Digital High-Torque Servos. This is the helicopter version which will default to heli settings when powered up and does not have a ratcheted throttle stick.
**Additional Technical Info Will Be Added When It Becomes Available.**
FEATURES: Futaba's FASST (Futaba Advanced Spread Spectrum Technology) shifts every two milliseconds virtually eliminating signal conficts and interruptions unlike other 2.4GHz systems that only stay on one or two frequencies Dual antenna diversity enables FASST system to automatically and seamlessly select the best reception between the two antennas built into the receiver ensuring that the aircraft stays under constant control of transmitter regardless of altitude.
Newly designed Dial-N-Key jog dial with joy stick button allows cursor movement in four directions for very user friendly navigating through menus and programming.
INCLUDES: Futaba 7C 2.4GHz Transmitter, R607FS FASST 7-Ch Receiver, charger, four S3152 Digital High-Torque Servos, instruction manual, transmitter battery
SPECS: 7C 2.4GHz Transmitter
R607FS FASST Receiver (FUTL7637)
Size: 1.6 x 1.1 x 0.35" (40 x 27 x 9mm)
Power Requirement: 4.8 - 6V
Current Drain: 80mA (at no signal)
Weight 0.25oz (7g) without case
S3152 Digital High-Torque Servo (FUTM0311)
Speed: .22 sec/60° @ 4.8V, .18 sec/60° @ 6V
Torque: 69 oz-in @ 4.8V, 87 oz-in @ 6V
Weight: 1.5oz (42g)
Length: 1.6" (41mm)
Width: 0.8" (20mm)
Height: 1.5" (38mm)
COMMENTS: The 7C 2.4GHz System is available in the following configurations;
FUTK7000 Airplane Version w/4-S3142 Digital High-Torque Servos
FUTK7001 Heli Version w/4-S3152 Digital High-Torque Servos
FUTK7002 Airplane Version w/4-S3004 Standard Servos
FUTK7003 Heli Version w/4-S3001 Ball Bearing Servos
*All include R607FS Receiver and $$$$$350.00 large
this is a copy job hehehe
Old 12-19-2008, 08:27 PM
dude7422
The 6-channel DX6i uses the same full-range DSM2™ technology found in the Spektrum DX7 and includes an impressive list of programming features for both airplanes and helicopters that are simple to access and use. It comes with the new AR6200 DSM2 6-channel receiver that is robust enough to use in large models yet compact enough fit in many park flyers. The DX6i is also compatible with all existing Spektrum aircraft receivers. Whatever kind of flying you do, the DX6i can be adapted to most any model in your existing collection that requires 6-channels or less.
Key Features
Full range 2.4GHz DSM2 6-channel radio
10-model memory
ModelMatch
ServoSync
Roller/selector user interface
Attractive and ergonomic design
Proven DSM2 technology
Rudder dual-rate
Large LCD display
Integrated timer
Contrast Adjustment
Dual-speed trim scroll
Model name and type
Throttle cut
Trainer Mode
Model Copy
Travel adjustment
Sub-trim
Servo monitor
Dual rate and exponential
Compatible with any existing DSM and DSM2 receivers
Airplane Programing Features: Flaps, P-mixes, Dual aileron, V-tail, Delta, Differential
Heli Programming Features: Gyro adjust, Graphic throttle curve, Graphic pitch curve, P-mixes, Revo mix, Swash type (Normal, and CCPM 120)
Adjustable stick length
Direct trim access display
Included.
DX6i system
AR6200 DSM2 reciever
4 x AA batteries
Bind plug
price 179.99 is that a good price????? this is a copy paste radio from hobbycity
Old 12-25-2008, 12:50 PM
dude7422
found another radio system
http://www.scaleflying.com/category_s/39.htm
Old 10-03-2010, 01:53 AM
xcellair
hey all,, was wondering how many have the 9 channel wfly and various recirvers,,and prices,, e mail let me know of the latest and best prices you guys know off,, thanks phill
Old 10-07-2010, 10:18 AM
dude7422
ORIGINAL: xcellair
hi xcellair learn from my bad deals just buy a futaba or a spektrum save your self alot of bull crap man rc radios is one item you get what you pay for no cheap dates to be found i have tried lol
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
