Esky Lama V3 2.4 Ghz
I just took a good look of the Esky Lama V3 2.4 Ghz heli and got impressed by the price. The blades are also really cheap. What are your opinions of that heli? Also, i want to ask if the upper blades are the exact same as the lower ones.
RE: Esky Lama V3 2.4 Ghz
it's quite a reasonable heli although the cheapness of the blades tells the story that you'll be replacing them lots! the top set cannot be identical to the bottom as they rotate in opposite directions!!
you obviously have flying experience and if you are going to get into the heli side of things as seriously i would suggest skipping the co-ax and get yourself a FP or CP and take it nice and easy whilst learning!#
have fun
Matty )
have fun
Matty )
