CX3 Arming Issue
After a rather bad crash (upside down on shaft upon hard floor...) I changed all blades and flybar, checked all connections. When i try rearming the unit, the servo arms seem normal anddo go to the center but the 3 in 1 keeps flashing red. nybody can help, please?
you might need to re-bind the Tx to the Rx?!
that and have a really close inspection of all visible wiring (magnifying glass wouldn't hurt!) to check for any looseness, etc.!
Matty )
Matty )
Might be a no brainer so pardon if it is. Ihave caught myself on a few occassions not making sure both the throttle and the idle were not in their resting position. I have seen this cause the symptoms you are describing.
Cheers!
Cheers!
