Kit or RTF????
#76
AZ
RE: Kit or RTF????
The swash plate can get whacked out of location or adjustment fairly easy. It is also just as easy to realign it as well . Once you know what you are looking for, it is super easy to adjust again.
#77
RE: Kit or RTF????
ORIGINAL: Solman
#78
AZ
RE: Kit or RTF????
move your controls to see which one does which function. If you screw it in, it will go forward, screw out, backwards. Same concept for roll.
#79
RE: Kit or RTF????
ORIGINAL: Solman
Thanks the Swash plate still does not look level(this is when it is powered down) but I flew inside and it was easier to control. I am glad I did not buy a FP or CP Heli. this one will keep my occupied for a while. I did read that if you adjust or screw in that can give you move forward flight?
#80
AZ
RE: Kit or RTF????
I don't worry about the swash plate being lvl on these micro's. They are set pretty close and just adjust as needed. It is also using a two prong swash plate compared to the three pronged swash plate on CP heli's.
#81
RE: Kit or RTF????
this MCX is a lot of fun as I get better with this would it be a wise choice to skip a FP and go to CP like the Blade SR? (with training kit of course.) will be awhile before I move up though.
#82
AZ
RE: Kit or RTF????
Are you using a sim? Either way, the flight characteristics are the same unless you get something like a MSR. So unless your next purchase is a ultra micro, get something like the SR and press on.
#83
RE: Kit or RTF????
no clue if this applies to that heli, but I know the swash plate can come apart on my CX3, if it does, it gets all over the place and control is wishy washy. check that I guess....
