RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   LP5DSM and MSR Problems Plz Help! (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/10259002-lp5dsm-msr-problems-plz-help.html)
McGregentine 01-12-2011 05:06 PM
Ok so a while back i bought the CX2 and it came with the LP5DSM receiver. well It never tuned right. well now i have bought the MSR thinking it would be easier to adjust so when i fly its not spinning or diving forward when all i do is put the throttle up. i have the adjusters all the way to the oppisite spin side but its still spinning and strafing left. so im guessing its the Receiver. If anyone could tell me how to tune then reset an tune again or knows anything about this problem please help.
dooleyje 01-12-2011 05:40 PM
RE: LP5DSM and MSR Problems Plz Help!
The heli is way out of trim. For the tail center the tail trim and when you turn your transmitter on then plug your battery in on the heli..DO NOT TOUCH IT, when the blue light come on wait an additional 10 seconds before moving the heli so the gyro has time to set.. Center yout other trims. While observing the heli from the rear, the two links on the swash should look like the following description. While looking from the rear the left link should be above the canopy while the right link will be down almost below the canopy lip. It will look as though the swash is bent to the right and forward. If you look at your links as you move the right stick it will give you a clue as to how to fine adjust them. If you links are misadjusted the heli will also toilet bowl on the air.
Jim
