Remove post????
How do you mark a post as solved, or remove it if it no longer is valid?
RE: Remove post????
You can comment that its solved, other than that just leave it. If your question and the solution are there, then maybe it will help a fellow modeler searching for the same issue later on.
RE: Remove post????
This problem is SOLVED
Thanks, I was wondering about the "solved" posts. |
| All times are GMT -8. The time now is 10:36 PM. |
