RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   Beginner Tx Settings Question for 200 S / 230 S (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/11638833-beginner-tx-settings-question-200-s-230-s.html)
garyv440 05-09-2017 05:58 AM
As an rc heli beginner and owner of a Blade 200 S bnf and a Spektrum DX6 gen 3 Tx,this is my first time setting up a profile for my heli.... I have been struggling to understand some of the parameter settings directly from the manual.
Question 1:
I set Aux 1 " panic mode " to switch "A" and reversed it., the book recommends button "I "....or does this only need to be reversed when putting "panic mode " on the button " I " ?
Question 2:
I created my D/R and expos on a 3 position switch, or is it only recommended to put D/R's and expos on a 2 position switch?...
Thanks ...Gary
cloudrider 01-02-2018 04:28 PM
Hi Gary,
Now Jan 2018 I've not been on the forum for some time and only just read your post. Have you had any success getting to grips with you Spekrum DX6?
Ab2048 06-03-2018 03:57 AM
New to helis also. 200S BFN to DX6 scenario also
My situation is in flight mode1 while throttling up servos drive swashplate towards rear elevator and right aileron slowly. Have to counteract with a lot of input. Same in mode 2. Mode 3 however no swashplate movement while takeoff. Once airborn I can switch to mode 1 or 2 and heli flies normal.
harryxtc 10-20-2020 05:46 PM
Read the manual and do a recalibration flight, should sort it out
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
