RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   engine advice (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/1808245-engine-advice.html)
jason515 05-12-2004 08:38 AM
engine advice
i'm having some trouble with my engine setup. it's a TT36, bought used, and probably ready to be replaced. anyhow, i'm having trouble keeping it running. it starts right up, doesn't die when the glow driver is removed, and idles fine. the problem is when i throttle up, and hit about 1/4 throttle, the engine dies. i have had several local experts look at this, and even adjust the mixture for me. it works fine for a tank or two, and then back to readjusting. after the engine is really hot, it runs fine. but it's frustrating getting to the hot point. i've been told to just replace the engine, and my problems will be solved. i have a 50 conversion kit ready to install, but i just want to know why this engine is giving me so many problems.
JR Venture 30
TT Pro 36
JR 6102
GY401
OS #8 Glow Plug
Cosmo 15% Hover Special
OS 50SX-H waiting to be installed
thanks,
Jason
bdphil 05-12-2004 11:04 AM
RE: engine advice
Sounds like something is causing it to go lean. Maybe a hole in the fuel line, or dirt in the carb/or clunk.
The engine may be just be junk, but it's probably something simple. Change all the lines, clean everything out and give it another go.
Ben
FHHuber 05-12-2004 01:00 PM
RE: engine advice
If the above doesn't work...
Check for a cracked metal (brass or aluminum) line in your tank stopper... (don't forget to check the clunk line inside the tank.... a hole in that will drive you nuts.)
Flush or replace the fuel filter (you do have one don't you?)
Prophex 05-12-2004 02:38 PM
message for FHHuber
Yes, FHHuber, you have my approval to reply to this thread and all the others to !!!
NOW HAPPY ?!
(just trying something)
jason515 05-12-2004 07:01 PM
RE: engine advice
would muffler type make a difference? i cracked the stock one, and replaced it with a revolution pipe.
FHHuber 05-13-2004 12:27 AM
RE: message for FHHuber
ORIGINAL: Prophex
NOW HAPPY ?!
LOL... best response I've seen to the "Awaiting aproval" message. ;)
Now I'm happy.:D
jason515 05-13-2004 06:08 PM
RE: engine advice
i got the engine out last night, and think i found the problem. when i crank it over by hand, and look into the exhause port, i see two things. 1.) when the engine is almost at full compression, i can see air bubbles leaking around the side of the piston. 2.) sevearl scratches on the side of the piston.
