22E help
I'm still having problems with my walkera 22E. Aprox. how much throttle should it need to start hovering. It seems like im getting close to full throttle on a full battery and does nothing. Sometimes it shakes a little bit, sometimes it spins slowely in a circle. Also theres nothing holding the tail blades on, they can slide right off. I may be missing a part, but I don't remember anything there out of the box. Does anyone with the same model know what I'm talking about?
RE: 22E help
after i almost beat mine up the same 1, i flew it into bench in gym after that i count get it off the ground i had to go on-line a look at the potions of the top blades on-line and on the box they all look even not the main blade but the 2 little nubby blade top of them i don't know what they call them yet I'm new to all of this but see if it works i put the 2 blades even and it worked for me word 2 the wise get a crash kit if u don't have 1 good luck [8D]
RE: 22E help
There should be a small bushing-like peice of plastic that holds the tail blades on. It slides over the tail rotor shaft. I lost mine in a crash and now I am using a tiny zip tie, cinched down on the shaft next to the blades. As to your not getting off the ground, there are two knobs on the top of the TX. They control your maximum pitch at full throttle and your zero pitch point. Turn on your heli with both motors unplugged to see if you are getting good postitive pitch at full throttle. If not you will need to adjust these knobs. They can only be adjusted when the lock/unlock switch on the back is in the unlock position. When you push it back to lock, it saves the current setting of the knobs.
| All times are GMT -8. The time now is 07:30 PM. |
