Tailboom length?
What are the advantages/disadvantages in longer and shorter tail booms.
Thanks |
RE: Tailboom length?
The longer the boom you run the longer the main blades you can run without chopping the ends off your tail blades. But you would need the appropriate engine to swing the blades and the appropriate belt to turn the tail blades (or shaft)
