Controller help
On my blade cx the right stick when i move it to the left it turns to the right and when i turn it to the right it goes to the left. This problem just happened ive been flying my CX for quite awhile before then it just started happening.
RE: Controller help
Your aileron channel got reversed somehow. Switch it and all should be well.
RE: Controller help
Control Test Procedure from the BCX Manual (Page 12 - 14)
If when you do the control test, the controls do not respond properly, then you would double-check the location of the servo connections on the 4-in-1 unit. These should be positioned as follows (when viewing the helicopter from behind): Channel 1 (Lower Port) – Forward aileron servo Channel 2 (Upper Port) – Rear elevator servo Once you have confirmed that the servo connection locations are correct, all controls should be functioning properly. If this is not the case, then let us know because we'll be really curious. Per the manufactuere, ff you do encounter any problems with your Blade CX responding properly to the transmitter, do not fly. Contact Horizon Hobby’s Product Support staff at 1-877-504-0233. |
| All times are GMT -8. The time now is 11:52 AM. |
