RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   VOYAGER E PROBLEM please help (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/4338328-voyager-e-problem-please-help.html)
sazmo33 05-31-2006 08:38 PM
will a E-flight six channel transmitter with built in mixing ccpm work with my voyager e.
Charlie 06-01-2006 03:53 AM
RE: VOYAGER E PROBLEM please help
If your going to move up to the Voyager E, I would recommend you get yourself a good radio that has the features your going to need to setup the Voyager right (pitch/throttle curves, ATV settings, remote gain for the gyro, sub trims, mixing, etc). That E-Flite radio is basically the bottom of the barrel radio. It would be more trouble then it's worth to try and use it.
sazmo33 06-01-2006 08:56 AM
thanks for the help.But could it be used or not.
Charlie 06-01-2006 09:59 AM
Yes it is possible to use it (anything is possible), you would have to use the receiver that come with it. Everything on the heli would have to be setup mechanically as that radio has no features. Like I said, it would be more of a pain in the butt then it's worth.
If your planing to stick with the heli hobby your going to need a good radio. The Voyager E is not much smaller the a 30 size heli, it's a big step up from a Blade CP, you should have the right equipment to run it. If you going to try and nickle and dime your heli your probably in the wrong hobby. Don't get me wrong, I'm not trying to be a smart *****, I'm just telling you the reality of the heli hobby.
If you start nickle and dimming helis together someone will get hurt, it's just a matter of time.
