RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   big problem (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/5900701-big-problem.html)
RC Walker 4 05-25-2007 11:54 AM
big problem
I know i have asked this already but i didnt understand how to do it my walkera 4 is in disaster spins and half of the controls on my transmitter i dont have any clue what they do the slides are confusing what do they do ?? The manual that came with it has no use at all i need help urgent cheers in advacnce.
mrasmm 05-25-2007 07:24 PM
RE: big problem
the sliders are to just adjust the center position of the joystick so that you don't have to constantly compensate for it. For example if the tail is drifting to the left , nose to the right, then you need to adjust the rudder slider to the left.
try this manual... it's basically the same thing, just a different brand. It might help you out
http://www.venom-group.com/print_mot...NR2_Manual.pdf
if you still need more help don't hesitate to ask.
make sure your controls are going the right direction and that everything is spinning the right direction. If you still have troubles let us know =)
Whirley Bird 05-25-2007 08:04 PM
RE: big problem
This is what I do.
(FIRST A WORD ABOUT SAFETY)
DO ALL THE BELOW AT A ROTOR SPEED NO MORE THEN NEEDED TO SEE WHAT THE HELI IS DOING)
1. First to avoid ground effect,I mount my helies on an old magazine rack TO GET AWAY FROM THE ROTOR WASH BEING BLOWN AGAINST THE FLOOR.
2.I secure it to the top of the rack with rubber bands.
3.I run it up with all sticks and sliders centered then see what it wants to do.
If it wants to lean to 1 side then make the correction on the linkage,(usually 2 turns)
Then fire it up again and now maybe problem 1 is gone but the nose may want to go up or down.
Again adjust the appropriate linkage..
As for your tail rotor you may have to adjust the linkage or maybe remove the servo arm and go up or down just 1 spline on the servo shaft.
When you do all this put the heli on the floor and see how it acts.
It will seem a bit unstable as long as the blades are so close to the floor but when you bring it up about 4 feet, stay away from it and sight in on the blade tips and make sure they track really nice and close.
You should only see one blade top at the speed where it starts to lift or hoover.
Next tie some mono line (APPX 5 feet should do) on each side of the fly bar bar as close to the head as you can.
If it's nose or tail heavy then move the battery around until that heli is hanging horiziontal.
All 5 of my helis here pull straight up off the floor and I can let go of the TX and they just sit there and sort of move around a bit.
Let us know how you made out.
Vegas/
