RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   servo problem (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/7009561-servo-problem.html)
roadracer01 02-01-2008 08:50 PM
servo problem
One servo (Hitech HS-81) does not perform like I would expect. It reacts to my commands but occasionally it seems to recenter its self.
I move the radio control stick to full travel back and forward several times and occasionally the servo stops traveling about 20 degrees. This results with my swashplate not being level. This is a newly assembled helicopter and I have never flown.
Is the servo bad or is this a typical result of a newbie not doing something correct?
badazzbusa 02-01-2008 09:32 PM
RE: servo problem
Remove the ball link and try it, just to make sure nothing is binding. Also, try it in another ch. port. If the problem still occurs then the servo is bad.
With the ball link removed and the power off, work it back and forth by hand. If it sticks at a certain point or feels real rough then one of the gears is damaged.
