Hello + Help
Hello all.
I just finished my Raptor .30, and setting up the servos I found that the tail rotor servo is not returning to center when you put full stick inputs in. there is nothing binding on the rods everthing is nice and smooth, is this normal with the heli not running? I am running a Futaba 401 gyro and a JR XP8103 radio. Thanks in advance |
Hello + Help
if your gyro is in hh it's normal. you should trim your rudder mechanically in rate mode while hovering before using hh.
Hello + Help
Yep the gyro is in HH I will turn the HH off and try that
Thanks |
| All times are GMT -8. The time now is 04:10 AM. |
