How tight for tail blades
How tight should the tail blades be set?
RE: How tight for tail blades
I set mine like main blades, little resistance, but loose enough for centrifugal force to put them in check
Thanks, Droggy someone told me to set them real loose so they would fall on their own weight
I have see them both ways.I run mine loose it seems fine........:D
I run my semi tight. Another words, if they are straight and I hold the heli up then shake it they will fall.
horses |
