RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   Need Help (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/8533570-need-help.html)
[email protected] 03-01-2009 09:12 PM
Need Help
My belt cp drifts to the left with full trim to the right . Any ideas? I am knew to this hobby and is there a correct way to adjust the flybar? Or how do you adjust the flybar? Thanks guys.
nothinbetr2do 03-01-2009 09:21 PM
RE: Need Help
you need to adjust the swash plate, the servo that controlls the left and right needs to be moved 1 tooth. center the trim tab on the remote and try again. keep making small adjustments like this untill you get the result you want
jerrymac 03-02-2009 05:54 AM
RE: Need Help
When you say it drifts to the left, do you mean all the time, or just during take-off? It is normal for it to drift left when taking off due to rotor downwash and the fact that the tail blades will push it left while trying to keep the heli pointed straight. If it drifts left all the time than most likely the swashplate is not level.
To check the swashplate, first UNPLUG the wires to the motor. Then turn on the Tx and then plug in the battery in the heli to power up the Rx. Next, flip the 'idle-up' switch to the on position and check the swashplate to see if it is level. If it is not level than just pop one of the ball links off at one of the servos and lengthen or shorten the linkage rod until the swash is level.
Most important, make sure that you unplug the wires to the motor first so that the rotor blades won't spin up as they can cause some serious injury if they hit you. Oh, yeah and when checking the swash make sure both sticks are at the mid-stick position..
gordons 03-03-2009 06:03 PM
RE: Need Help
Need Help - Am having trouble trimming the tail rotor servo (T-Rex 450) Radio in use JR 6102 Gordons
RC-Lover 03-09-2009 01:59 PM
RE: Need Help
Hi, every one
I just crashed the Raptor G2 ..... every things are gone except the receiver (WK-701) and the transmitter (WK-0701) .
Now i want to uprade to 450 size . I just got the EXI 450 version. Can i still using the transmitter. and receiver for the uprade ?.
bad400 03-09-2009 02:06 PM
RE: Need Help
ORIGINAL: RC-Lover
Hi, every one
yes
RC-Lover 03-09-2009 02:12 PM
RE: Need Help
Thanks Bad400.
I don't have the manual for the transmitter.... how do i set up? ... ( there are 12 litle swicth in the back of the transmitter)
bad400 03-09-2009 02:30 PM
RE: Need Help
honestly im not up on the stock radio`s for exceed.it is an exceed stuff right?
the only thing i can tell you for sure that most after market servo`s like jr, and futaba`s polarity are the oppeset of say e-flite, esky, ect...... hxt900`s are standard polarity
once you have the heli built make sure you UNPLUG the motor and move the joy sticks in all direction`s. this will tell you what way things are moveing.
the dip switch settings i am not sure on, you could try looking up that paticular radio on what ever site you bought it from.
they should have a downloadable manual for it
RC-Lover 03-09-2009 02:57 PM
RE: Need Help
thanks again bad400 for your supported...
yes it's an exceed.
I talked to the guy from tech support, He said when I remove the crystal.. it will be reset..
RC-Lover 03-09-2009 03:01 PM
RE: Need Help
Man... once again, I love this forume it's help me learn alots .
[email protected] 03-09-2009 08:51 PM
RE: Need Help
I have a honey bee king 4 6 moths all i can do is hover is there any ease way to make a circle
bad400 03-09-2009 09:30 PM
RE: Need Help
not sure what you mean by easy.
it just like turning left or right, then add some alliron
if going left you move both stick`s to the left
if going right you move both sticks to the right
