RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Motor...
Old 01-04-2012, 10:45 PM
lenachen
Default Motor...
I have a current problem with my 450. The motor drive gear (autorotation bearing) doesn’t work properly. Within the flight the motor runs but no power on the rotorhead. The Heli falls down. It’ is possible to move the motor drive gear in both directions without moving the motor.
I was looking in RC-Line Helicopter forum and I find more people have that problem. One people said KDS would know the problem. It would be a tolerance problem with motor mainshaft and KDS have changed all motor shaft.
Anyone knows about this? What can I do to avoid further problems?
Old 01-05-2012, 12:53 AM
daniel88
Default RE: Motor...
Please confirm the batteries  is normal or not?  If the battery normal discharge, then
recommend you replacing ESC and reset.
Old 01-06-2012, 04:54 AM
JunoWelson
Please confirm the batteries  is normal or not?  If the battery normal discharge, then recommend you replacing ESC and reset.
Hit the mark, personal idea
Old 01-10-2012, 12:10 AM
Henriquedeton
learned a lot,thanks for sharing
