Frustration beyond belief
I'd love to try to hover or something.... if I could only get the freaking engine to start.
It's a TT Raptor 30 V1 (TT36).
Any suggestions? I set the needle 2 turns out, spun it... nothing... spun more... nothing. Finally I got it to start with the throttle wide open, at about 1.75 turns out, by holding my finger over the exhaust.
Shouldn't it start with the throttle closed, when cold?
I get nothing.
Thoughts?
I get nothing.
Thoughts?
My Feedback: (15)
NJ
RE: Frustration beyond belief
Ahhh, nitro tuning...so much fun NOT!
If it only runs with your finger over the exhaust opening then it sounds to me like a fuel delivery problem. Check for leaks in the lines, tank and filter. Turn the needle back in an set it to the factory recommended starting point. Make sure fuel is getting through the lines. Sometimes a clogged fuel filter can cause problems. Does the tank have a primer? If yes they can cause air leaks.
HTH
HTH
Most crittical part of the T39 (and probably the tt36 as well) is the idle needle. They can be a pain. after months of battling, a friend here just upgraded to an OS 37, put a smile on his face.
I think in the end, I managed to either burn out my glow plug, or drain my plug igniter's battery. I'll try again Sunday when I get back in town. If that fails, I'll replace the fuel lines and bypass the header tank.
Just how cold was it? Below 40 degrees, it is harder to get them to fire. Holding your finger over the exhaust helps prime it and is often useful.
Tom
Tom
