picking a TX has become mind boggling !!
NC
i'm wanting to upgrade my stock radios..(2) HoneyBee King 2's to a computer radio...but all the choices have wore out my brain.
i just want something good but not overkill....
DX7-probably top of the class..do i really need all it has
DX6-will it be outdated after a while
Dx6i- no really good evaluation..as it's not out yet
Futaba 6EX...sounds decent
any feedback is greatly helpful...good or bad
thanks KC
thanks KC
AL
KCinNC:: ... Futaba 6EX...sounds decent ...
6EXA ... flys airplanes only
6EXH ... flys helis only
6EX 2.4GHz ... flys both
The 7Cs and 9Cs are good options too.
I don't need all that my 9C has to offer ... today ... but what about next year or the year after??
The 9C will allow me to expand a little more.
AB, CANADA
as stated before, i suggest that you get the best radio you can afford. there is also a new 2.4ghz 7ch radio coming out from futaba. you may outgrow your heli's but you don't want to outgrow your radio (too often anyway)
if you dont think you will ever fly more then 6 helis then get the futaba. if you think you'll have between 6 and ten helis then get the dx6.. if you thnk some day you may have more then 10 helis and some of them are gasser/nitro then get the dx7.
all can be found right here.. this is a great guy.. he is always ready to answer any of your questions customer or not. his shipping and customer service is the best,,ask anyone here...
all the above tx's are great.. it just depends on how far you want to go.. jake..
[link=http://ka-planes.com/inc/sdetail/1126]http://ka-planes.com/inc/sdetail/1126[/link]
NC
ORIGINAL: tippy
Which 6EX?
the 6EX 2.4 is what i was looking at
as far as expanding.....that's up to the wife
AB, CANADA
true enough but you might find some uses for that extra channel on a 7ch radio. volt meter, led lights, wheel retracts on a scale project... etc.
WI
radio is the heart of your R/Cs i have a JR 9303 but after 25+ years i also have 7 planes and 3 helis +1 on order .. not counting the ones i have sold or crashed ....get the best you can afford then you do not need to upgrade later in 25 years i have had 10+ radios
a DX7 would be GReat
AB, CANADA
yep, if the JR 12x had come out sooner I wouldn't have this DX7 myself... maybe when the 12X does come out I can sell it to someone like the OP...
AL
ORIGINAL: Druss
AB, CANADA
because i don't like using a y harness, just more wires to bundle up. i'm talking about the little voltage monitors that light up or make a sound when your lipo battery is dying.
LA
My vote goes to the Futaba 9C if you have room for it in your budget. it will fly Heli's, planes, and gliders and has enough features to keep you happy until you start flying quad engine warbirds or twin turbine jets. I bought mine thinking "what will i ever need nine channels for" and within six month I was using eight of them on a glow plane.
AZ
Not only does the DX-7 have another channel but it has more programing features and a larger screen than even futabas new 7c 2.4
WI
if i didnt have a JR9303 and was starting over i think i would start witrh a DX7 its a good radio ,,, look at the reveiw in RC Heli #18 Dec 07 ... its rated high
I'm going to go through all that maybe next year. My 8u does both and with a Campac I am in good shape but times are changing. Programing is a nightmare on it. But with this 2.4 and now into helis, going to have to support both. Not sure if the 9c does 2.4 as i have not research it but i have programmed one for a friend with no manual and makes my 8U seem like dinosaur
AB, CANADA
ORIGINAL: Cyclic Hardover
AL
ORIGINAL: Druss
futaba doesn't have a 9C w/ 2.4 yet but i'm sure it's coming. there is a spektrum module for it though.
will stay with the swappable modules.
And there is a SS module for the 9C (8-channel) ... it's Futaba's "spectrum" module ... not Spektrum (brand name)
And are they expensive !!!
http://www3.towerhobbies.com/cgi-bin...?&I=LXRTU7&P=7
NC
ORIGINAL: RussWisc
AB, CANADA
actually Spektrum does have a module for futbaba radios which uses spektrum receivers.
http://www.spektrumrc.com/Products/D...odID=SPMMSFUT9
AL
ORIGINAL: Druss
I still doubt that Futaba will come out with a dedicated 2400Mhz 9C any time soon but is bound to happen eventually.
AB, CANADA
totally agree, they are releasing a 7C that is 2.4ghz in dec/jan though so i think the 9C will be out next year sometime. JR is releasing the 12X and Airtronics is releasing an 8ch 2.4 next year so the pressure will be on.
AL
ORIGINAL: Druss
2.4Ghz is coming and with 2.4Ghz there will be no reason for frequency swapping. At that point ... the previously "moduled" TXs will become SS only.
TX
Don't forget Jim Drew's 2.4 system- XPS. I see the module and receiver price for a 9C has dropped from $250 to $200. In fact, most of his prices across the board have dropped. Just remember that converting a 9C to 2.4 will leave you with an 8 channel radio- you only get the 9th channel when using PCM. Oh yeah, the 2.4 gHz 6EX is a VERY basic transmitter. I'm only using it as a stopgap measure until the radio I really want is available. I feel sooo limited using the 6EX although I prefer Futaba's 2.4 over Spektrum's.
AB, CANADA
I've looked into the XPS system and it's not as advanced from what I can see as the Spektrum or Futaba FASST, they only use one connection instead of 2 so if you lose the one it searches and locks onto a free frequency but during that time you may lose control. The idea behind the dsm2 is that it uses 2 frequencies so that there is redundency.
This is just what I have been told. Besides, the cost of a new DX7 is only $50 more than the module for a 9C.
