Blade 400 or Mini Titan
I'm thinking of getting a Heli i cant decide on which one to get
I have kind of narrowed it down to Blade 400 or a Mini titan
there really are no good reviews on the Blade 400
Im not really looking at price or if its RTF or not i am more looking for Durability and Flight characteristics
Any recommendations?
AB, CANADA
RE: Blade 400 or Mini Titan
The electronics that come with the blade 400 aren't that great. By getting the mt you can put what you want on it, seems like the better way to go if you have the money.
ORIGINAL: Druss
Jim
Jim
AB, CANADA
ORIGINAL: redbaron9898
what about performance wise
I thought that the spectrum radios were great! What part of the electronics are bad?
radio? servos? gyro?
IL
If you're just starting out, with no existing radio or electronics, then the 400 is the way to go. Especially if the LHS stocks the parts!
My Feedback: (14)
As always, it depends on your skill level and what you expect. I have a B400 so I can step out my garage and get a flying fix without abandoning my wife to the kids for 2-4 hours. I wouldn't recommend it for a beginner, but anything above that should be able to handle it. The stock servos are not the greatest, so I swapped them out for HS-65HB's and found a true digital servo (Spektrum DSP75) for the tail. I put in a gy401 just because that's what I'm used to. Other than putting on FRP blades, that's it. The B400 is more capable than my current skill level (I'm more of a scale flyer than 3D), but I've seen others put ones nearly identical to mine through some pretty rough 3D routines. If you see any of my helis doing 3D, that's the signal to run the other way.
Here's a link to the discussion on tips, tricks, and mods for the B400: http://www.rcuniverse.com/forum/m_6843765/tm.htm
Good luck on your decision!
Ok i have the radio gear but nothing else
I called my LHS and they stock Blade 400 parts And T-rex 450 parts
Should i just treat myself to a T-rex 450 SA?
MD
The TREX 450 SA is an awesome heli! Like the Mini Titan, YOU put in your own electronics and you'll get the build experience that will help when you have to rebuild after a crash.
A good thing about the SA is that its cheaper than the SE and as you break things, you can always upgrade to metal.
If you get the TREX 450 SA, the "standard" good electronics are as follows:
Cyclic Servos: HITEC HS-65mg (3 of them)
Tail/Rudder Servo: Futaba S9650
Gyro: Futaba GY-401
Good luck bro!
Skarn
Gyro: Futaba GY-401
Good luck bro!
Skarn
ORIGINAL: Skarn
Gyro: Futaba GY-401
Good luck bro!
Skarn
Gyro: Futaba GY-401
Good luck bro!
Skarn
Jim
MD
ORIGINAL: dooleyje
The 65HB is a little cheaper in price and are just as good as the 65MG. Jim
Skarn
ORIGINAL: Skarn
I'd have to respectfully disagree with you on that one. Yes they are fine for the trex but the gears being that they are not metal tend to strip a lot more. I've read post after post of these stripping...and yes it's not hard to replace the gears, but it's a PITA to me.
Skarn
ORIGINAL: dooleyje
Skarn
Yep the 2100 is a good gyro and smaller than the 401.
Jim
IL
redbaron,
To answer your question, the mini-Titan is probably more durable but definitely shows better flight characteristics than a Blade 400. I researched both (in addition to the T-Rex) myself about 6 months ago. Here is the general consensus.
- Blade 400 Is actually smaller than a mini-Titan & T-Rex. It's also a little squirrely and needs to be "tweaked" out of the box to get it to fly smoothly. The magazine reviews that have now been written on the B400 agree. It needs better servos on the swash right out of the box. One reviewer actually didn't recommend it for a beginner. The main advantage is LHS parts support and getting a heli/radio RTF that's "almost" ready to fly (but will not handle as well as a mini-Titan or T-Rex).
- mini-Titan Has excellent durability (even the standard plastic version) and the flight characteristics are simply SUPERB! The excellent ratings it got in the reviews are right on. It's most complete kit is still an ARF though so you have to add your radio etc. and then get some help trimming it initially but after that it's ready to rock & roll. Most well stocked LHS's (including mine) carry mini-Titan parts too.
It's not on your list but just FYI, the T-Rex is pretty good but is a "little" harder to work on because of the side frame design. I've also personally flown a professionally set up T-Rex SE and it WOULD NOT fly or even hold a hover as easy as the mini-Titan. It's main advantage is local parts support.
Hope this helps.
Dave
-Blade CX-2
-mini-Titan
-E550 Raptor
Hope this helps.
Dave
-Blade CX-2
-mini-Titan
-E550 Raptor
RC david
thank you for helping me
I think i am going to my LHS today and asking them what my best option would be.
Im leaning toward the mini titan now...Don't you have to cover the blades?
IL
No problem.
The MT blades are already covered but you will need to glue the blade grips (ends) on. I (and most people) don't like the stock woodies. They are "ok" to start but the preferred ones are Align Wood Pro Blades (about $13.00)
If this is your first heli I'd REALLY suggest going with the mini-Titan. I think you will be much happier all the way around. To be totally honest, if I had started with a T-Rex I may have quit RC helis by now just out of disappointment in it's flight stability. I know some people say they fly pretty good but that was not my experience with a brand new one set up by a LHS. It was pretty unstable. []
The mini-Titan is much quieter too.
Dave D.
Dave D.
RC david
RC david
im pretty new to helis
i have had an HBK2 that was good for learning but not much more
i want something that i can get into 3D with
Jim
I have a 3800kv brushless motor will that work in the mini titan?
Jim
it is an esky outrunner motor
i used it on my HBK2
i only have a 25 amp esc though
Jim
i think i am going to get the mini titan
get new blades right away
So the esky motor will work?
just get a better esc?
i only have a telebee gyro too
so here is what i was thinking of buying
1 mini titan kit
4 HS-65hb servos
1 align bl35g 35A
i have:
Radio tx and rx
telebee gyro
esky 3800kv motor
and a battery
***will this work?***
1 mini titan kit
4 HS-65hb servos
1 align bl35g 35A
i have:
Radio tx and rx
telebee gyro
esky 3800kv motor
and a battery
