RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Testing the G401B Gyro!
Old 06-08-2009, 05:26 PM
  #51
KC36330
Default RE: Testing the G401B Gyro!
ORIGINAL: JojoManigbas
............The servo horn is facing up, do I move it one whole up or one whole down?
you're kidding right? moving it in is always toward the servo regardless of which way the horn is pointing...........
Old 06-08-2009, 05:57 PM
  #52
JojoManigbas
Sorry, I guess I need to read more carefully.
I'll move it one hole in.
Old 06-08-2009, 09:40 PM
  #53
blvdbuzzard
There is a very long thread on these gyro's at RC Groups.  They cover everything about them.  I reqd that one first.  They also have a list of servo that work well with this gyro.
I ordered two of them from chchelicopter.com before the ones at deal extreme showed up.  I tried every servo I have and I could not get the gyro to not drift.  I tried it on 3 different helicopters with 4 different servos.  It drifted, very, very slowly but it drifted.
I check my setups and went over the helicopters with a fine tooth comb looking for any vibrations.  Nope.  No matter what I did they drifted.  Well I got pi$$ed and ordered 2 of the Logitch 2100T and 3100G combos for $110.00 each.  They work great.
A friend of mine had me put his EXI 450 together.  Well he had some funky clone of a telebee that work about as good as your thumb does.  I pulled it and put on the G401B and it worked just perfect.  No drift and holds like velcro.  He has a INO llabs high speed digital servo.  Look like the G401B and that servo like each other.
I still have 1 on the shelf.  I may order a Hyperion servo or see what I can come up with using the servo I have.  This gyro seems to like high speed servo in the .07 to .05 speed servos.  The faster the better.
Dru.
Old 06-08-2009, 10:06 PM
  #54
JojoManigbas
So a fast servo is needed.
Does it have to be digital?
Old 06-09-2009, 01:11 PM
  #55
blvdbuzzard
The best rated servo is the Hyperion 09.   It seems to work the best.  It runs about $34.00.  there is a GWS servo that works too.  I just do not know the number.
Dru.
Old 06-09-2009, 04:26 PM
  #56
Charlie
Charlie's Avatar
I believe it's the [link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4696]GWS PARK HPX F[/link], it works great for me (so far).
Old 06-10-2009, 11:12 AM
  #57
dude7422
Iuse one also Deal extreme gyro 22.88 I filled inside case with GE silicone to help support
thethree tiny pc boards inside ,,some of these gyros quit working in short time and i think it
is from the boards joins coming loose other words a little pm
ID:	1215723   Click image for larger version
ID:	1215724   Click image for larger version
ID:	1215725   Click image for larger version
ID:	1215726   Click image for larger version
Old 06-10-2009, 01:44 PM
  #58
JojoManigbas
dude - This is a great tip. I'll do the same.
Thanks!!!
Old 06-13-2009, 01:03 PM
  #59
dude7422
JOJO make sure eg silicone is fully cured before power up unit
watch someone will chine in and say the EG silicone will ad too
much weight to heli tail lol
Old 06-13-2009, 01:22 PM
  #60
noobflyer01
the silicone will add too much weight on the tail!    its going to throw your whole balance on the heli off.
just kidding....couldnt help myself.
Old 06-23-2009, 04:01 PM
  #61
T3beatz
T3beatz's Avatar
Hey guys I have the G401b gyro from DX on my Frankenstein HK-450 got a Little video of it in action with the Hyperion DS-12GCP servo (.06 speed @6v .08 @ 4.8v) from AlleRC.com... Its a little bigger than the hyperion DS-09 but it also has more torque and can handle more volts (6v vs the 5.5v from the sub-micro DS-09)... They cost the same and I think the DS-12 is more suited for a 450 size heli, its actually a heli tail servo...
I also have the G401b from XMseller, they work the same...
OH yeah, I also tried the GWS HPX Park F servo and even though its analog its a good budget tail servo for someone who is starting and is only doing hovering flips and circuits, I didn't do any super 3d with it (I've only been flying helis for 2 months!)
http://www.youtube.com/watch?v=SkxMReap2HU
Old 06-30-2009, 08:54 AM
  #62
dude7422
t3 what are you using to video looks good
Old 06-30-2009, 10:20 AM
  #63
T3beatz
T3beatz's Avatar
ORIGINAL: dude7422
I use one of the Aiptek HD mini cams from walmart, cheap, but they work pretty good and look good also... http://www.walmart.com/catalog/produ...uct_id=8145151
Old 07-01-2009, 09:26 AM
  #64
dude7422
T3BEATSz thank you much for link
