Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
Reload this Page >
Head Speed drops in - Pitch?
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 07-04-2009, 12:49 PM
infernorcteam
Default Head Speed drops in - Pitch?
Hope you guys can help. I've tried everything to correct this problem. When I put my Raptor 30 inverted for more than 2-3 seconds the engine boggs down and my head speed drastically drops. I'm afraid if I kept it inverted, the engine would eventually stall. I've tried ajusting both the pitch and throttle curves with no success. At first I wondered if it was the engine. It's an O.S. 50 Hyper with the carb only opening to about 80%. But after thinking about it, that really cannot be becasue it flies great from 0-12 degrees positive!
I know, the next crash will be a 50 so that I can let that motor run!
Old 07-04-2009, 02:06 PM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Head Speed drops in - Pitch?
Check your needle setting, if you're running too rich upright its possible you're overly rich when it flips inverted and the fuel pressure changes.
Old 07-04-2009, 03:08 PM
infernorcteam
Thanks BarracudaHockey, I will check that.
Old 07-04-2009, 04:23 PM
tadawson
Why only 80%? If it bogs inverted, it would tend to indicate the need for more power. Also, have you verified your blade pitch to confirm that you have the same pitch range positive and negative, and that 0 occurs where you think it does? You may also be getting too high a pitch inverted, which will also cause you to bog . . . . Curves will only do so much, and if the mechanical setup is off, may not be able to fix this problem . . . .
- Tim
Old 07-04-2009, 11:33 PM
infernorcteam
80% because its I'm running an OS Hyper 50 with 550mm blades. The 50 running 100% turns too high of a head speed. I've varified the blade pitch to confirm the pitch range multiple times, 12 positive and 9 negative. I know the true fix to this problem is to ultimately run 600-620 blades which I plan to in the future. I bought this heli used but never flown with two extra 30 crash kits and no engine. I had an extra Hyper 50 and figured it would work fine. It works well right side up!
Old 07-05-2009, 02:17 PM
Bugzilla
Bugzilla's Avatar
I've never messed with nitro before so I gotta ask. If it's bogging with 550's on it, how would longer heavier blades solve the problem?
Old 07-05-2009, 02:34 PM
evan-RCU
evan-RCU's Avatar
He'd go to 100% throttle...
My suggestion is to make the leap to the 50 setup and them troubleshoot from there.
Old 07-06-2009, 08:54 AM
dooleyje
I would check on my fuel system. The bog could actually be a lean run in the inverted position as you stated it runs great upright. Your clunk could be out of the fuel when inverted or you may have a pin hole in the fuel line in the tank that uncovers when inverted. I would use a header tank ( make sure your header tank is level with your carb pickup/needle valve. Some fuel tanks are a little different mounted in helicopters such as when upright it is lower than the carb and inverted it is above.
Jim
Old 07-07-2009, 09:02 PM
infernorcteam
Hey Jim, it's funny you mentioned the header tank because I wondered that myself and actually purchased one a few weeks ago and just never got around to putting it on. I'm gonna have to put it on and play with the carb because both lean and rich conditions have been mentioned. I'll let you know what I find out.
Brandon
