RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Blade Tracking EXI 500
Old 07-01-2010, 06:56 PM
RC RedHots
RC RedHots's Avatar
Default Blade Tracking EXI 500
Has anyone every had a set of 500 sizeheli blades that will not track?
One time they do and the next time they don't.
The ones I have are fiberglass and Yes they are imports off ebay.
It's like one blade has more flex in it then the other.
I know I may have made a bad choice!
What do you think?
And yes I have checked the feathering shaft & rubber bushings, they look good!
Any idea, trash them and go with a better set?
RCREDHOTS
Old 07-02-2010, 01:28 PM
john josey
Default RE: Blade Tracking EXI 500
I`ve had wooden blades that gave me tracking problems but never glass ones. From what you describe, i would have to agree it most probably is the cheaper blades.
Is it possible you could 'borrow 'a set of quality ones just to be 100% sure ?
Old 07-02-2010, 01:45 PM
Solman
I buy cheap blades all the time. I have learned as to which ones that I like and which ones that I don't. It is always possible to get a bad set. Don't just put them down because you got one bad set. The possibility of receiving a bad set is always possible. That said, I am going to ask the million dollar question. Did you balance them prior to flying?
Old 07-02-2010, 03:03 PM
RC RedHots
RC RedHots's Avatar
Yes sir I did!
With a gram scale and a see-saw and with a main shaft one by on and center line marked then re balance.
I have gone as far and scufed one of them and sprayed on paint to not have to use tracking tape.
One blade is flexing more then the other, that is the only thing I can see.
I am going to change the damper bushings and see what happens.
I also going to order a new set of blades.
Oh this is 2 pair blades that are junk.
Thanks All any other input welcome!
RCREDHOTS
Old 07-02-2010, 04:44 PM
RC RedHots
RC RedHots's Avatar
In the past hour changed I changed the bushings in the head and that was a no go, same problem.
So I ordered some CF blades.
Any other ideas let me know please!
I am going to give the fiberglass bladesto my grand kids to dig holes with, if they work for that!
Thanks RCREDHOTS
Old 07-02-2010, 09:56 PM
Solman
I am not a big fan of fiberglass blades either. I have a few sets as spares, but I am not a big fan of them. You can get CF blades cheap enough and are much better.
Ok, I've heard of people using a gram scale to check the weight. I don't do it and haven't found a need to do so yet. Your second part has me all confused on how you did it. Did you use one of these?
http://cgi.ebay.com/Rc-Carbon-Blade-Balancer-Align-Esky-Walkera-450-K217-/320555630406?cmd=ViewItem&pt=Radio_Control_Parts_A ccessories&hash=item4aa29abf46#ht_2422wt_1023
Old 07-02-2010, 11:33 PM
RC RedHots
RC RedHots's Avatar
Yes I use the see-saw (like you have the link)
I usea gram scale to check each blade weight.
I also center balance each blade root to tip.
Thanks for your input!
I did order 2 sets of carbon fiber blades.
No more deals of the day for me!
Thanks again RCREDHOTS
Old 07-03-2010, 07:01 AM
Solman
Why would you balance it from root to tip? I don't see the purpose of that. I personally never understood putting on a gram scale either because if it balances on the see saw, then it is balanced and that is what you want.
Old 07-03-2010, 08:16 AM
RC RedHots
RC RedHots's Avatar
I guess it kind of redundant mainly to check if the blade weight after adding tracking tape.
More or less a backup, just to make me feel better I guess.
But bottom line the fiberglass blades I bought are junk.
I spent more time then I should have with them.
I have a Blue Ray and have balanced and installed a set of blades and with in a few hovers they are tracking perfect.
And yes I know the difference in length makes a big difference's. 450 /500
As I said I ordered 2 set of carbon fiber blades and will see what the outcome is.
For the life of me I can't think of any other problem other then one blade flexes more then the other.
Thanks For Your Input.
RCREDHOTS
ORIGINAL: Solman
Old 07-03-2010, 01:19 PM
Solman
Yea, just like anything else, it is always possible to get a set of bad blades. Heck, it happens with batteries on occasion.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
