Gyro Question
NC
Gyro Question
It may be a dumb question but!
Should I setup the tail in headlock or in rate mode, and adjust the servo for hover.
I have it setup in rate mode and hovers great with a little tail drift.
When I switch from rate mode to head lock I notice the slider moves to the tail boom.
I have not tried to hover in head lock.
Thanks RCREDHOTS
Let me add to my question can it be setup in headlock and rate mode and be able to switch from one to the other without adding any trim vs versa.
RE: Gyro Question
Us older people set it up in rate or when the servo and linkage are "0 and 90" there is a slight gap when yo ufold the blades. Newer pilots ignor it and most systems fly fine ignoring it.
Me, I'm more comfortable setting the gap, I feeel the system is better centered that way.
RE: Gyro Question
....Newer pilots ignor it and most systems fly fine ignoring it.
I have even seen them installed such that there was only 10 degrees of throw in one direction with 50 in the other!!!
Yet it will fly OK until you try to yaw in one direction compared to the other or the gyro tries to feed enough rudder in that one direction that may be required to keep the tail from blowing out. There will be far less control one way then the other, Consequently there will be many more times when the heli's tail will blow out when worked hard. That is why you will find some say a certain model of gyro blows out in fast backward flight, while others say it does not, (this will even effect the consistency of the piro rate in certain maneuvers).
So though it may seem to work under less demanding situations, it will not be working near as well as it can if properly set-up mechanically in Yaw-rate mode first for no drift in the hover.
RE: Gyro Question
Put it in rate mode
Make sure the arm is 90 degrees to the rod.
Make sure the tail pitch slider is centered.
Put it in heading hold and go fly.
There's other ways to do it but that works. Setting up a nuetral hover in rate mode on small helis on a 401 just limits your pitch throw.
