RCU Forums
-   RC Helicopter General Discussions (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/)
-   -   Futaba GV-1 governor set up (https://www.rcuniverse.com/forum/rc-helicopter-general-discussions-129/10577516-futaba-gv-1-governor-set-up.html)
Kaos 06-16-2011 01:19 PM
I just put the first 3 flights on my low-time X-cell 60 and I'm having a little problem with my new Futaba GV-1 governor. It works fine as far as holding any of the 3 switchable RPM's I've set, but the governor will not shut off when I reduce the throttle stick to idle. The heli just sits there, whirring away at 1500 RPM. I thought I set up the throttle stick limits and idle cut off properly, but maybe I'm missing something. To review, I set the throttle stick to low then hit the data button; throttle to high and again hit the data button. Last, I set to idle cutoff and hit the button again.
I'm using a 3-position switch to select RPM's (in this case, 1500, 1550, 1600) and also a separate switch to turn the governor on and off.
If I instead set the throttle stick to one notch above idle (fast idle) and then pushed the data button, would that solve the problem with the governor not disengaging?
-Kaos
X-cell 60 Custom
OS.61 SF
JR 550T gyro w/servo
Aurora 9 radio system
tadawson 06-16-2011 01:36 PM
RE: Futaba GV-1 governor set up
Enable StSw in the GV-1 . . . that is what is required to have the GV-1 drop offline based on stick position (StickSwitch)
Without that (which is the default) it ignores stick position once engaged.
- Tim
Kaos 06-17-2011 07:09 AM
ORIGINAL: tadawson
- Tim
You were exactly correct Tim. I brought up the StSw menu and sure enough, it was INH. I punched the data button
once and then it indicated OFF. Advancing the throttle stick past about 25% it shows ON. ON, OFF, ON, OFF :-)
Thanks!
-Kaos
tadawson 06-17-2011 08:23 AM
No problem! Enjoy!
- Tim
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
