RC heli help
Hello, I'm having trouble with the removal of the bearings in the seesaw and the head, any tips?
Thanks https://cimg9.ibsrv.net/gimg/www.rcu...63d12d5562.jpg https://cimg0.ibsrv.net/gimg/www.rcu...29e2eae084.jpg |
you have to get a small nut and bolt in there with some sort of collar to rest against the nut. use 2 small wrenches to turn the nut and bolt. the head of the bolt will then push the bearing out.
A little heat always helps.
I've tried heat but I need to get the tools to get them out, are there any tools you know of?
Thanks |
Heat it in an oven to around 350 degrees for 10 to 20 min. Use a line up tool and wedge it in the bearing. Move it around and try to pul it out. If that doesn't work try cutting a notch in a rod . Insert it in the bearing and pull it out.
I'll definitely give that a try, I'll need to get a bearing puller first
Originally Posted by Thunder man
(Post 12717104)
Oh, I assumed a line up tool was another name for it, my bad
put a bolt and nut in there to push them out. real easy
